Originally posted by TER-OR
Looks like you're on the right path. The K-50's a good choice. Remember the marketplace here for used lenses and other gear.
I've been intrigued by the 4/3 format but decided to get a Pentax Q for the bantam weight camera, with an older Olympus rugged compact for other uses (it's pretty nice).
Thanks for your reply TER-OR
M4/3 is nice in that you get the compact size and good IQ, but it can be limiting. I like to be able to shoot with old manual glass and while you are able to do so with M4/3 using adaptors, it's not always ideal. Once you start adding large lenses to the small bodies, stability becomes an issue and IQ starts to go downhill. I have large hands, and having a good size grip will be nice and being able to use legacy Pentax K mount glass without the need for adaptors will be nice too.
I will definitely check out the marketplace before I buy the 50mm 1.7 lens, or any other lens for that matter.
I must admit to being intrigued by the Pentax Q7 which has the same sensor as the MX-1, but didn't want to go to another mirrorless system, especially one even smaller than my PEN cameras. The MX-1 is perfect for everyday use and K-50 will fit the bill for an interchangeable lens systems. Can't wait to get it.
