01-25-2014, 09:30 AM   #1
Lens Coatings
how much is the lens coating relevant on image quality.
reading a lot on lens construction.
other than the housing which is a relevant factor on the lens longevity, the percieved facet is the optics, optical formula, the RI of the glass and the coating.
i wish to suggest that caotings ought to be given its place under the sun an entity on its own.
though scientific analysis is difficult as coating formulations are largely proprietary does it make a diffence a huge YES.
for example the various SMC coating, anf the resounding T* coating of zeiss(this really creates this contrast and flare resistance). Then the recent nano technologies.
Thus has time come to have its identity under the sun
shou
01-25-2014, 09:37 AM   #2
Canada_Rockies's Avatar
Good insight. I agree with you.
01-25-2014, 06:36 PM   #3
i know and wish technical insights are aired, will put my insights after compiling
01-26-2014, 03:56 AM   #4
Moderator PEG Judges
Kerrowdown's Avatar
Welcome to the forum, all sounds way to technical for me, I just look at the finished images to see if I can spot a difference.
I will follow this thread with interest, provided you only use small simple words so I can keep up.
01-26-2014, 04:37 AM   #5
savoche's Avatar
Welcome! Sounds like you belong firmly over in the lens discussion sub forums.
01-26-2014, 09:41 AM   #6
QuoteOriginally posted by kerrowdown Quote
... provided you only use small simple words so I can keep up...
Is there such a thing in Scotland?
01-26-2014, 09:44 AM   #7
Kerrowdown's Avatar
QuoteOriginally posted by Canada_Rockies Quote
Aye, your, round, for, a, dram.
Lots of wee words put together have meaning.
01-28-2014, 04:22 AM   #8
wikipedia
Optical lens design is the process of designing a lens to meet a set of performance requirements and constraints, including cost and manufacturing limitations. Parameters include surface profile types (spherical, aspheric, holographic, diffractive, etc.), as well as radius of curvature, distance to the next surface, glass type and optionally tilt and decenter. The process is computationally intensive, using ray tracing or other techniques to model how the lens affects light that passes through it.
Performance requirements can include:
Optical performance (image quality): This is quantified by various metrics, including encircled energy, modulation transfer function, Strehl ratio, ghost reflection control, and pupil performance (size, location and aberration control); the choice of the image quality metric is application specific.[1][2][citation needed]
Physical requirements such as weight, static volume, dynamic volume, center of gravity and overall configuration requirements.
Environmental requirements: ranges for temperature, pressure, vibration and electromagnetic shielding.
Design constraints can include realistic lens element center and edge thicknesses, minimum and maximum air-spaces between lenses, maximum constraints on entrance and exit angles, physically realizable glass index of refraction and dispersion properties.
Manufacturing costs and delivery schedules are also a major part of optical design. The price of an optical glass blank of given dimensions can vary by a factor of fifty or more, depending on the size, glass type, index homogeneity quality, and availability, with BK7 usually being the cheapest. Costs for larger and/or thicker optical blanks of a given material, above 100–150 mm, usually increase faster than the physical volume due to increased blank annealing time required to achieve acceptable index homogeneity and internal stress birefringence levels throughout the blank volume. Availability of glass blanks is driven by how frequently a particular glass type is made by a given manufacturer, and can seriously affect manufacturing cost and schedule.
Process
Lenses can first be designed using paraxial theory to position images and pupils, then real surfaces inserted and optimized. Paraxial theory can be skipped in simpler cases and the lens directly optimized using real surfaces. Lenses are first designed using average index of refraction and dispersion (see Abbe number) properties published in the glass manufacturer's catalog and though glass model calculations. However, the properties of the real glass blanks will vary from this ideal; index of refraction values can vary by as much as 0.0003 or more from catalog values, and dispersion can vary slightly. These changes in index and dispersion can sometimes be enough to affect the lens focus location and imaging performance in highly corrected systems.
The lens blank manufacturing process is as follows:
The glass batch ingredients for a desired glass type are mixed in a powder state,
the powder mixture is melted together in a furnace,
the fluid is further mixed while molten to maximize batch homogeneity,
poured into lens blanks and
annealed according to empirically determined time-temperature schedules.
The glass blank pedigree, or "melt data", can be determined for a given glass batch by making small precision prisms from various locations in the batch and measuring their index of refraction on a spectrometer, typically at five or more wavelengths. Lens design programs have curve fitting routines that can fit the melt data to a selected dispersion curve, from which the index of refraction at any wavelength within the fitted wavelength range can be calculated. A re-optimization, or "melt re-comp", can then be performed on the lens design using measured index of refraction data where available. When manufactured, the resulting lens performance will more closely match the desired requirements than if average glass catalog values for index of refraction were assumed.
Delivery schedules are impacted by glass and mirror blank availability and lead times to acquire, the amount of tooling a shop must fabricate prior to starting on a project, the manufacturing tolerances on the parts (tighter tolerances mean longer fab times), the complexity of any optical coatings that must be applied to the finished parts, further complexities in mounting or bonding lens elements into cells and in the overall lens system assembly, and any post-assembly alignment and quality control testing and tooling required. Tooling costs and delivery schedules can be reduced by using existing tooling at any given shop wherever possible, and by maximizing manufacturing tolerances to the extent possible.
Lens optimization
A simple two-element air-spaced lens has nine variables (four radii of curvature, two thicknesses, one airspace thickness, and two glass types). A multi-configuration lens corrected over a wide spectral band and field of view over a range of focal lengths and over a realistic temperature range can have a complex design volume having over one hundred dimensions.
Lens optimization techniques that can navigate this multi-dimensional space and proceed to local minima have been studied since the 1940s, beginning with early work by James G. Baker, and later by Feder,[3] Wynne,[4] Glatzel,[5] Grey[6] and others. Prior to the development of digital computers, lens optimization was a hand-calculation task using trigonometric and logarithmic tables to plot 2-D cuts through the multi-dimensional space. Computerized ray tracing allows the performance of a lens to be modelled quickly, so that the design space can be searched rapidly. This allows design concepts to be rapidly refined. In most cases the designer must first choose a viable design for the optical system, and then numerical modelling is used to refine it.[7] The designer ensures that designs optimized by the computer meet all requirements, and makes adjustments or restarts the process when they do not.
^ Fischer, Robert E.; Tadic-Galeb, Biljana; Yoder, Paul R. (2008). Optical System Design (2nd ed.). New York: McGraw-Hill. pp. 8, 179–198. ISBN 0-07-147248-7.
Jump up ^ "Modulation Transfer Function".
Jump up ^ D.P. Feder, "Automatic Optical Design," Appl. Opt. 2, 1209–1226 (1963).
Jump up ^ C. G. Wynne and P. Wormell, "Lens Design by Computer," Appl. Opt. 2:1223–1238 (1963).
Jump up ^ "Dr. Erhardt Glatzel (Biography)". The Zeiss Historica Society. Retrieved July 21, 2013.
Jump up ^ Grey, D.S., "The Inclusion of Tolerance Sensitivities in the Merit Function for Lens Optimization", SPIE Vol. 147, pp. 63–65, 1978.
Jump up ^ Fischer (2008), pp. 171–5.
lens, lens coating, sun
Camo Lens and camera coatings theoicarry Pentax SLR Lens Discussion 4 03-10-2013 07:07 AM
Does Sigma Use Cheap Coatings? reivax Pentax SLR Lens Discussion 3 03-09-2013 09:59 PM
Older Pentax lens coatings bassek Pentax SLR Lens Discussion 16 09-28-2012 04:18 AM
DA* Lens coatings... sebberry Pentax SLR Lens Discussion 3 12-22-2009 12:28 AM
Newer lens multi-coatings better than the old ones? voltraizer Troubleshooting and Beginner Help 3 11-21-2009 09:32 PM
All times are GMT -7. The time now is 09:33 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
