Originally posted by 6BQ5 I agree with fretlessdavis about buying used when/if you choose to go digital. I would say you can go even further back in time along the Pentax line of DSLRs. The *ist series of bodies are also great. They may only be 6MP but they produces excellent quality images that can still fill modern high resolution monitors. The response times are slower than modern cameras so I would say that the *ist bodies are better suited to slower, more deliberate and thought out shots.
Another thing to note about the *ist bodies is that I would say that the used prices have pretty much bottomed out. What you see is what will be for a long time now. It may fall a little lower but I think inflation will kick in and keep the prices where they are at now. Some of the newer DSLRs will probably become cheaper on the used market in the future.
K100d or K10d is you have unsteady hands. The colors of the K100d with its CCD still hold up fantastically at this age. All my best digital shots were done on my K100d. It was supposed to be my backup camera, but ended up being my main one for Spring-Fall 2013.
Prints hold up perfectly to an 8x10 (larger if you don't shove your nose into them).
Used a K100d goes for about $125, a K10d for about $175.
The *ist series was excellent, too, and are around $100. No SR is a big hit comparing to a K100d, but the option of using the old TTL flash is awesome (makes auto flash work very cheap in easy in comparison to P-TTL)
