Originally posted by mee *waves*
Do you not have the 18-55mm kit lens? If not, you might find 50mm to be quite long for a walkaround focal length (unless you do portraits or the type)
I'd look at small zoom or, if you really want primes, a 35mm f/2.4 lens. It will give you a wider field of view and still affordable. Ideally, I'd get a small walkaround zoom lens and the primes for when I need the extra light (or sharpness).
If you're looking to photograph landscapes, you will want a much much wider lens.. maybe 18mm minimum.. but you've been lurking so you know how to research the site :c )
No, I bought the body by itself, because I wasn't convinced I wanted the 18-55. I knew the prime (first lens for me) would be perfect for a couple projects I am working on right now, which require portraits. I figured I would get only what I absolutely knew I wanted until I was sure which lens to get next.
Good call on the 35mm f/2.4...may need to work that into my prior thoughts on which lenses next. [Confirmed to myself that I have contracted LBA, just now...haha]
After I save up a bit, lenses 2, 3, and 4 for me will likely be:
2.) DA 18-135mm F3.5-5.6
3.) DA 15mm F4 Limited
4.) Pentax D FA 100mm F2.8 WR Macro
and maybe if I find a duffle bag full of money...Pentax DA* 60-250mm F4 and 55mm f/1.4 DA* SDM
Seem like a good list...?
