Originally posted by martbev Hi,
I've have a Pentax ME (not the super) with 50mm f1.7, 28mm f2.8, and 120mm f2.8 lenses. I bought a K-500 to be able to use the lenses with a digital back. I followed the setup help I found on this forum, and it works fine, except that there seems to be a blue cast over all photos taken with the M series lenses compared to the kit DAL lens. Did I miss a setting (white point or something)? Or is it just the way the camera displays the image?
Did you compare the DAL to the M lenses under the same lighting conditions and on multiple days? Does sun, shade, and indoors give a similar blue cast?
Are you shooting in JPEG or RAW? If RAW, what software are you using?
What is the white balance setting on your K-500? Auto should give reasonably good results in most lighting conditions.
And, as already mentioned, sample photos are very helpful to diagnose issues.
