Originally posted by christineart Thanks, Flixter :-) I will need to pick up additional items for the camera, Like extra batteries, I was looking on line and noticed that Wasabi batteries are not to expensive, anyone know how well they perform to the OEM batteries from Pentax? and is there any other items that I should get?
I have used 3rd party LiOn batteries on my Q7. They did not last as long but they worked fine - just had to recharge them more often. I finally had to buy the 2 Pentax LiOn as I was chewing through the batteries quickly.
Do you know how 'used' your K5 IIs is? (If not, no big issue, use the link below from one of our PF members. All you have to do is to take a picture with your K5IIs and upload the file .... assuming -of course - that the battery that comes with the camera is the original) The only reason I ask is that the more the camera is used (higher actuations) the more the life of the battery is shortened. If the number of actuations is getting up there (say ~ 8K+ ??? .... other more experienced PF members might have a better idea than myself) you are going to get much less than the stated # of shots. If this is the case, you might considering buying a new Pentax battery as there is nothing more frustrating than having your day cut short because you ran out of juice - twice! At least this way, you have one battery that would last all day of shooting. If it is low, then you should be ok with Wasabi.
Check Shutter Count & Camera Manufacture Date Online - EXIF Reader
As for other things you might need .... have you considered replacing the camera strap? A lot of people usually overlook this, but I find that the supplied Pentax Strap is too narrow and digs into my neck. After a couple hours of shooting, I find that it chafes my skin due to the weight of the camera and lens (this is when I usually really appreciate the light weight design of the K1000!!!) Now-a-days we have options galore for every shooting style that you like.
Cheers!
