Originally posted by Sabil can you help me, which one the best macro as you recommend compare
HD PENTAX DA 35MM F2.8 MACRO LIMITED BLACK and SMC PENTAX D FA 100MM F2.8 MACRO WR
also some plus minus each lenses
really appreciated your feedback.
They are both very, very good. Which is better depends on what you plan to take pictures of.
The main difference (for macro) is that the 35mm has a much shorter working distance then the 100mm. So, the 100 will be better for taking pictures of insects and other things you might scare away by getting too close, and when you don't want to use artificial light.
The 35 is (for most people, I think) better as an allround lens, and it is smaller and lighter. Good for inanimate objects (plants, watches, coins, etc), but hard to get really close without blocking out light.
You can read more about both of these (and many others) in the
lens review section.
Purely for macro you might consider other lenses as well, such as older manual 50mm and 100mm macro lenses (autofocus will not help you very much for macro anyway), or the Tamron 90mm or Sigma 70mm or 105mm macros.
