Originally posted by IsaacT I think my next lens will be the Sigma 10-20mm but I need to decide which to get. The f/3.5 is faster than the f/4-5.6 but is 260 dollars more. The f/4-5.6 is on sale right now at 399. The f/3.5 has HSM also which is cool/as opposed to the screw AF on the f/4-5.6
I assume you have read the PF staff comparative review of these two lenses? Read it carefully, not just the conclusion.
Here is a case for the f4-5.6 (given the relative prices):
1. HSM might be "cool" but screw drive is simple and reliable. And faster: in the PF forum test the f4-5.6 focused faster than the f3.5. Does it really matter if it is a bit noisier?
2. Most of the time with ultrawide lenses (e.g. for landscapes) you want to maximise depth of field, so it doesn't matter that the lens is slower. The Pentax 12-24 is only f4 and it's a fine fine lens. Also with a wide angle, in low light you can get away with a slower aperture at a wide angle than you could with a telephoto lens. Anyway at 10mm you are only talking about the difference between f3.5 and f4. And the cheaper lens seems to perform well wide open.
3. The f4-5.6 is lighter and less bulky and takes 77mm filters.
4. In the PF test there was little difference in IQ. Certainly not $260 worth.
One thing you might not have considered. All ultrawide lenses produce distortion and are prone to vignetting, falloff and chromatic aberrations. Do you have good software for post processing to correct these things (e.g. Lightroom, DxO Optics Pro)? If not, factor in the cost of that too.
