12-11-2015, 09:27 AM   #16
Na Horuk's Avatar
Lens and camera need to have same lens mount for them to be compatible.
Spotmatic is m42 mount, so you need m42 lenses for it. You can adapt m39 and m37 lenses if you have an adapter ring, but you should be able to find plenty of m42 lenses, so don't bother with that. K-mount lenses cannot be adapted to m42 cameras.
Pentax K-x and P3 have K-mount. This means both of them can use K-mount lenses. Just beware that not all K-mount lenses have the same features. Really old ones do not have AF. Really new ones do not have aperture ring (needed for some older SLR cameras). K-mount cameras can take m42 lenses with a simple adapter. I recommend buying genuine Pentax adapter, but there are knockoffs, as well. Note that some of the knockoffs are good, but some are bad and can get stuck/cause problems! Difficult to tell which, as these usually have no label.
So all you need is a m42 to K adapter if you want to use m42 lenses on K mount cameras. You will not be able to use K mount lenses on Spotmatic.
adapter, adapters, camera, cameras, custom, dpi, files, film, grain, lenses, m42, m42 lenses, megapixels, pentax, pentax screw, pentax screw mount, print, resolution, scan, scans, screw, screw mount lens, slr, spotmatic, steve, stop-down
Is it possible to mount flash used for Canon cameras on Pentax Cameras? pcchoon Troubleshooting and Beginner Help 6 05-09-2013 07:09 PM
Other than Pentax, which are the best small digital cameras accepting K mount glass? jpzk Non-Pentax Cameras: Canon, Nikon, etc. 15 10-11-2012 06:49 AM
Will screw mount lenses work on the digital pentax cameras? justtakingpics Troubleshooting and Beginner Help 6 05-25-2010 08:53 AM
Three screw mount cameras compared Nesster Pentax Film SLR Discussion 11 10-30-2008 03:27 PM
Pentax Screw-mount Cameras & Lenses Matthew Roberts Pentax Film SLR Discussion 7 04-21-2007 02:53 AM
All times are GMT -7. The time now is 10:24 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
