11-06-2014, 03:30 PM   #1
introducing myself - barham
Hello:
I am "barham", 74 year practicing trial judge in Meridian, Tx which is in Central Texas. I have a K50 and have had numerous 35mm Pentaxes over the years.
Other than introducing myself on this forum and hoping to learn something (even old judges can learn). I was wondering if someone could help me with the built in flash on my K50. It seems to me that I am experiencing overexposure with pictures taken less than 15 feet away. Is this normal, if so, how can adjust the flash. It seems ok at longer distances.
Thanks,
barham
11-06-2014, 03:37 PM   #2
crewl1's Avatar
HI barham and welcome.
The flash should have a setting option that will be available by pressing the flash indicator on the 4 way button when in shooting mode.
Once there press the lower of the the 4 way buttons to jump the display to the flash compensation setting.
Use the rear dial to set the flash at some slightly negative number.
Experiment till you find a setting that will work well in your typical distance.
It may be that you will need to change it up if you are shooting at different distances.
11-06-2014, 03:56 PM   #3
Moderator PEG Judges
Kerrowdown's Avatar
Welcome aboard, hopefully that's your issue already solved by crewl1.
11-06-2014, 04:41 PM   #4
MarkJerling's Avatar
Welcome to the Forum! I'm sure you could write a book about your court experiences!
11-06-2014, 05:26 PM   #5
Welcome, we are glad to see you, I'm sure you do not just show us your photos and tell us about your lenses!
11-06-2014, 07:40 PM   #6
normhead's Avatar
Welcome to the forum...
11-07-2014, 06:29 AM   #7
Rimfiredude's Avatar
QuoteOriginally posted by crewl1 Quote
Thanks for the info. I never noticed the compensation before.
11-07-2014, 06:46 AM   #8
TER-OR's Avatar
Welcome aboard!
Gary Fong makes a diffuser for the pop up flash. It works well, but is easy to lose. I lost part of mine, and have yet to buy a replacement.
flash, k50
Introducing myself Brandosan Welcomes and Introductions 4 05-06-2014 11:28 PM
Introducing myself RobertJRB Welcomes and Introductions 2 01-26-2014 03:42 AM
Introducing Myself califgrl Welcomes and Introductions 9 08-02-2013 04:57 AM
Introducing myself.. carlosq Pentax Q 5 06-15-2013 08:24 PM
Introducing myself lfgray1949 Welcomes and Introductions 2 01-19-2013 06:37 PM
All times are GMT -7. The time now is 01:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
