Originally posted by Oricman I've recently purchased a k30 with WR kit lens and the 55-300 telephoto.
Previously used Panasonic FZ150 another superzooms. Used to use Minolta SLR film cameras.
Find the Pentax needs a lot of work to get in focus. Trying to update firmware and see if I can improve things with different settings. I have used my partner's Canon 500D which seems a lot easier to use. Also images are coming out a bit dark when taken in sunshine. Not sure why - so many options to tweak!
Welcome! I just started using a K-50 after coming from Olympus cameras and I had some dark photo issues too. I believe both Panasonic and Olympus default to lock exposure on the half press of the shutter button. The K-50 does not and needs to be set to do that if that's the way you shoot. I always use the center focus point and recompose so I was accidentally metering for the new composition. I don't have the camera in front of me, but it was an easy setting to find if I remember right. It looks like the k50 and k30 are similar cameras. Good luck!
