Hey, welcome!
Originally posted by Zazu That mean that a 15mm lens become a 22.5mm. But the f - number also change............ a f4 will become a f6 (f5.6 adjusted).
I don't like to look at the "equivalence" as such. I know some people love it, but many of us think its just a needless complication.
Originally posted by Zazu I have tried to use a FF lens on a APS-C sensor and adjusted the Hyper focal scale for the 'extended' depth of field......and it doesn't work.
I have a personal theory on hyperfocal. The original definition of hyperfocal is the nearest focus that gives acceptable sharpness (aka DoF) all the way to infinity. But the problem word is
acceptable. I think what was once acceptable on film is no longer acceptable on modern day digital cameras to a lot of photographers. This is because modern day digital sensors have much more resolution, and photos can be easily viewed at "1:1 zoom", where each pixel on the photo corresponds to one pixel on the monitor. This means that photos are captured with more sensitive technology and scrutinized at closer range. Our personal standards also go up, because we are often exposed to "ultra sharp, super detailed" photos, especially online, but also with HD TV and other media.
Another problem is that modern DA lenses have a very short focus throw (designed for fast AF, not for Manual focus) and often don't have distance scales at all, much less DoF scales. With many brands, even the distance scales on there are miscalibrated (so the label 3m, for example, does not actually focus 3m from the camera sensor, as it should). This makes hyperfocal, or zone focusing at all, very difficult if not impossible.
So here is my advice: You take that lens that you want to use in hyperfocal, set it to the aperture that you want to use, and then you do tests with it. Put the camera on tripod, use 2 sec timer, and you take a couple photos, only adjusting focus a little bit between shots. Then you look at the photos to find which focus setting is the one that is truly "hyperfocal" on your gear, according to your standards. Now you can either remember where to focus, or you can even mark it on the focus ring.
Also, hyperfocal is only possible with wide angle lenses, because they will give you a wider apparent DoF. Which lenses would you like to use hyperfocal focusing on?
