03-30-2016, 01:21 PM   #1
Helllo
I am new to photography and interested in learning .. what is a good camera and lens set for landscape photography ?
03-30-2016, 02:07 PM   #2
Moderator PEG Judges
Kerrowdown's Avatar
Welcome to the forum, have a good look around the place and you will find many helpful bits of information to help you decide.
03-30-2016, 04:54 PM   #3
I have a Pentax K-5IIS and use it with a Pentax 16-85. There are multiple lens/camera combinations that you can use that are available from Pentax. The K-mount is what most Pentax cameras have, which is used by most Pentax lenses. There is a selection of both Pentax cameras and lenses that are compatible with each other.
The following web address is to the selection of Pentax products. Most are usually available on Amazon also, along with B and H, and Adorama.
http://www.ricoh-imaging.co.jp/english/products/index.html
03-30-2016, 09:02 PM   #4
pjv
pjv's Avatar
Hi burningbrush. Welcome to the Pentax forums. If you look at the " user photo galleries " at landscape, you can see not only the photographs, but the EXIF data says what camera and lens was used. Good luck.
03-31-2016, 05:34 AM   #5
TER-OR's Avatar
Welcome aboard! Most of the camera bodies will suit you well. After that lenses are all personal preference.
I enjoy the DA21mm for that use, it's a fun little lens. The Sigma 8-16 is also an interesting lens to investigate.
photography
Helllo! meeksethan11 Welcomes and Introductions 5 04-23-2012 07:15 AM
Helllo from Garthorpe wooly Welcomes and Introductions 1 06-17-2011 03:37 PM
All times are GMT -7. The time now is 03:44 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
