04-02-2016, 03:02 PM   #1
Hi from Brisvegas
Hi everyone,
Greg from Brisbane here.
Looking forward to being part of the Pentax community
My first Pentax was a Spotmatic - coupled with a number of different screw-mounts that served me well through the 70's and into the 80's. The image below is a creation from the early days with the Spotmatic doing double exposures.
After a Z10 in 2007 I changed over to a K100-D before becoming the proud owner of a K-x, a great little camera that continues to punch well above its weight.
I'd appreciate advice from anyone who knows how to get my old Sigma 35-80mm F4-5.6 DL AF working on the K-x. ...It is the lens with the sticky rubber barrel decay problem...
The lens itself is still in good shape and I'm keen to see what sort of images it can produce on the K-x if I can get the shutter to fire.
Any assistance would be very much appreciated.
Cheers...Greg
CanoScan 5600F  Photo
04-02-2016, 03:08 PM   #2
Transit's Avatar
Welcome Greg spotmatic and K 100 guy here too :-)
The KX shutter won't fire? Have you got Focus priority turned on in the menu that would do it
04-02-2016, 03:12 PM   #3
Tas
G'day Greg, I moved from Brisvegas to Newcastle a couple of years ago and expect to be back there again in the coming months. There's a lot to capture and explore in and around Brisvegas, similarly there's plenty of information and threads to explore here on PF. Hope you enjoy doing both.
04-02-2016, 03:15 PM   #4
QuoteOriginally posted by Transit Quote
Thank you Tas - much appreciated
04-02-2016, 03:15 PM   #5
Thank you Transit - much appreciated
04-02-2016, 03:26 PM   #6
Hiya Greg
Welcome aboard.
I'd have a guess and say the lens is not set to the A position on the aperture ring? That will stop the shutter firing, unless you set up the camera as per this link.
https://www.pentaxforums.com/forums/58-troubleshooting-beginner-help/110658-u...x-dslrs-f.html
That should help with manual lenses, or if using an A lenses just make sure it's in the A position...hope that helps?
Cheers
Dean
04-02-2016, 03:55 PM   #7
pjv
pjv's Avatar
Hi Greg. Welcome to the Pentax forums mate. You will find that somebody here will know the answer to any question asked !!
04-02-2016, 04:50 PM - 1 Like   #8
Thank you
Many thanks for the prompt replies.
Dean, the YouTube video was very helpful - problem solved.
-Greg
04-02-2016, 05:22 PM   #9
AussieTrev's Avatar
G'Day, fellow SEQ member. We have a few from the SE corner. You will enjoy being here.
04-02-2016, 05:40 PM   #10
eaglem's Avatar
Welcome to the forum, glad you could join us.
04-02-2016, 06:01 PM - 2 Likes   #11
Transit's Avatar
QuoteOriginally posted by Dean Bradshaw Quote
I'd have a guess and say the lens is not set to the A position on the aperture ring?...
snap
04-02-2016, 06:14 PM   #12
Welcome!
04-03-2016, 01:10 AM   #13
QuoteOriginally posted by C_Jones Quote
Welcome!
Thank you C_Jones.
-Greg
---------- Post added 04-03-16 at 01:11 AM ----------
QuoteOriginally posted by eaglem Quote
Thank you eaglem
---------- Post added 04-03-16 at 01:12 AM ----------
QuoteOriginally posted by AussieTrev Quote
Thank you Aussie Trev
04-03-2016, 01:56 AM   #14
Moderator PEG Judges
Kerrowdown's Avatar
QuoteOriginally posted by peciacake Quote
problem solved
Welcome, wow issue resolution in double quick time too.
k-x, lens, pentax, post, spotmatic
hi from tuscany rabdo Welcomes and Introductions 6 02-04-2015 02:41 PM
Hi from a new Pentax user from Viet Nam minhdat_rhm10 Welcomes and Introductions 17 10-07-2013 04:07 AM
Hi from England and Hola from Spain oldbellsfarm Welcomes and Introductions 4 07-21-2011 12:10 PM
hello from brisvegas pirate63 Welcomes and Introductions 6 06-02-2010 02:57 AM
Hi from HI (hawaii) rapphaelray Welcomes and Introductions 8 01-25-2007 10:21 PM
All times are GMT -7. The time now is 11:53 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
