06-16-2016, 02:06 PM   #1
cannot downlod pics to pc
Hello all
I am extremely new to Pentax cameras and this forum. I have had my camera operational for about 2 days now and want to download to my pc. I have several pcs and the two I am using now are both running windows Vista one 32 bit one 64 bit with AMD 64 althalon x 2 processors. ( I know "Vista" groan.) Regardless I believe I should be able to download to one of these boxes. I have tried both direct camera to pc via usb cables and card readers. I did not shoot in RAW, only jpegs. I made the settings on the camera for the usb connections, I have installed Silkypix,the Process Jpeg box is checked.The sd card is a sandisk ultra plus xc1 80 mb/s with 64gb storage, I formatted the card when I inserted it into the camera, the write protect tab is open. I have swapped usb cables. Neither pc sees either the camera or the sd card. I have beautiful pictures on the camera lcd screen . What am I doing wrong? I can go to a Intel Win XP machine but in my experience XP won't see a 16 megapixl image(too big). Is it possible that the Pentax, Windows, Silkypix etc combination is not compatible with AMD processors? Maybe you want to stand outside my front door from which I am about to hurl this camera? Any suggestions are appreciated. Address available for a nominal fee.
06-16-2016, 02:12 PM   #2
QuoteOriginally posted by shart4legged Quote
Hello all
Click on "My Computer" - that's where the camera or card reader should show up. If they don't, try rebooting and go at it again. Sometimes a full shutdown followed by a manual restart (rather than the restart option) is needed to get quirky USB devices to start working again.
If connecting your camera to the PC, you'll most likely want to keep the default USB settings.
06-16-2016, 02:18 PM   #3
photolady95's Avatar
Location: Cruising PentaxForums and watching your back.
Question, when you plug the cable into the USB port, is the camera turned on?
06-16-2016, 02:27 PM   #4
Turned on?
I turn it on after the connection is made
06-16-2016, 02:33 PM   #5
paulh's Avatar
Is your USB card reader compatible with those larger 64+ gb SD cards? I had the same problem and had to upgrade my USB card reader.
Also as photolady suggested, try turning the camera on before connecting the camera usb cable - worth a try.
06-16-2016, 02:49 PM   #6
ramseybuckeye's Avatar
You seem to be doing everything right. plugging the usb cable in, turning the camera on after it is plugged in. I had a AMD Vista system until just a few months ago and it had no problem handling files, that should not be a problem. It actually sounds to me that you may have a usb port that is not working, which is not uncommon. Maybe you already have tried another port, but if not please try it. When these things happen it is frustrating, but it's usually something easy to fix, once figured out. good luck.
06-16-2016, 02:59 PM   #7
QuoteOriginally posted by ramseybuckeye Quote
Thanks for the reply I was really questioning this combination as I have had experienced MSWinxxx and Amd conflicts before. I am really at a loss here. The Usb ports see my Cannon point and shoot with no problem. Should I perhaps update the camera firm ware?I have been reluctant to do it because the camera is so new to me and I don't want to introduce any more variables to this problem than there already are.
06-16-2016, 03:05 PM   #8
Well, I can tell you it's not your AMD system because I've run AMD and Windows Vista, XP and now Windows 7 with no problems with any of my cameras, including a K-30. Did you try what I said, turn the camera on before you plug into the USB port?
06-16-2016, 03:18 PM   #9
QuoteOriginally posted by photolady95 Quote
yes , tried multible ports , with the camera on and off then turning the camera on.
06-16-2016, 04:00 PM   #10
SpecialK's Avatar
Kind of basic but did you open the Canon folder to get to the DCIM sub folder and then individual files?
06-16-2016, 04:23 PM   #11
On you camera settings under Interface Options make sure the USB Connection is set to MSC. Actually try MSC or PTP if one is not working. edit: Actually I just noticed that you tried a card reader also, so this would not be the problem. Something is keeping the PC from recognizing it, I don't think it could be your camera or card.
06-16-2016, 04:34 PM   #12
to photolady95
Since you seem to have had experience with a k-30 on vista can you tell me what size sd card you use? paulh may have something when speaking to the size of card I am using. Is 64gig too much for these old operating systems and machines?
06-16-2016, 04:54 PM   #13
Should not be a problem. After Windows XP, NTFS can see any size file. It was only FAT32 that had a problem with file size being too large but that was only in transferring files, not seeing them. I believe Paul might have been talking about a older card reader not seeing your larger card, especially since you're using a SDXC instead of a SDHC card. But if you are using the USB cable, that wouldn't or shouldn't be a problem on Vista.
06-16-2016, 04:56 PM   #14
Do you get any message when you plug the USB cable in and turn on the camera?
06-16-2016, 05:04 PM   #15
No, no messages no sounds. Its like nothing was introduced to the computer.
Silkypix sees that there is a card (drive F but does not open the files
cables, camera, card, downlod pics, pc, pentax, processors, sd, usb, xp
Question Cannot upload photo to contest Eddie75 Site Suggestions and Help 4 06-05-2016 03:27 PM
I cannot return to RAW on K-5IIs JimmyDranox Troubleshooting and Beginner Help 4 04-13-2015 12:31 PM
Cannot seem to get sharp photos nonstopnick Troubleshooting and Beginner Help 25 04-13-2015 08:39 AM
cannot download pics onto pc from pentax optio s12 help Visitors' Center 1 01-23-2014 09:41 AM
Why are PPīd pics better from PC than from my K200D? Jonathan Mac Digital Processing, Software, and Printing 11 11-19-2010 10:59 AM
All times are GMT -7. The time now is 03:27 PM. | See also: NikonForums.com, part of our network of photo forums!
