07-27-2016, 05:48 AM   #1
Question about the D FA 100mm F/2.8 Macro
When the D FA 100 mm F/2.8 Macro is mounted on a digital crop sensor Pentax body is the F/2.8 really F/4.2 since this a full frame lens?
1.5 x F/2.8=F/4.2 or does that not apply to this lens?
Any assistance is appreciated!
07-27-2016, 05:55 AM   #2
amateur dirt farmer...
pepperberry farm's Avatar
the crop factor (which should honestly be ignored, IMHO) only applies to the focal length (field of view), not the aperture....
07-27-2016, 05:56 AM   #3
QuoteOriginally posted by Joe M Quote
No it is always 2.8 regardless of the camera you put it on. The crop factor only affects the field of view. So 100mm on a 1.5 crop factor would be like you are looking through camera with a 150mm lens.
07-27-2016, 06:00 AM   #4
savoche's Avatar
What pepperberry said. The aperture is a physical attribute of the lens (as is the focal length), and will be the same no matter which camera you put it on.
07-27-2016, 07:13 AM   #5
TER-OR's Avatar
In my experience chasing insects you're not going to use f2.8 anyway. You'll have it stopped well down, I've recently been shooting f16 with a Sunpak ring flash and been VERY happy with the results. In sun without the flash I'd stay in the f11-f13 range.
07-27-2016, 07:28 AM   #6
UncleVanya's Avatar
If you mean how much depth of field you get then be ready for endless debate. What I'd say is that you get more depth of field with any lens when mounted on a smaller sensor than on a bigger one. But the exposure should be essentially the same. In practice you can argue that higher ISO options on larger sensors allow different exposures and you can argue subject distance and framing equivalence / but in the end none of this cares if the lens is full frame or cropped. A 100mm lens on APSC at f2.8 is going to work the same even if it was a massive 6x7 lens on an adapter.
07-27-2016, 08:07 AM   #7
QuoteOriginally posted by TER-OR Quote
For most people who buy this lens for its intended purpose on anything, not just insects, they're in close and DOF concerns will drive you far away from maximum aperture. OTOH if you are also using it as a general short tele, f/2.8 is nice to have in a lens of this focal length, especially (as was the case with me for a while) if all your other glass which reaches that focal length is zoom and at least a stop slower (e.g. the D-FA 28-105 is TWO stops slower at 100; the DA tele zooms are probably down to f/4.5ish by this stage so a stop and a half; the 60-250 is f/4 all the way, so one stop; only the 50-135/2.8 keeps up in speed terms), and this one is WR and full frame to boot.
07-27-2016, 10:24 AM   #8
Na Horuk's Avatar
The lens does not become dimmer if you put it on a smaller camera. Ignore all equivalence unless you actually own both formats of cameras. In that case, equivalence can help you imagine what a lens rendering (FoV, DoF) might look like on the other format.
Also, the 100mm macro gives 1:1 magnification on FF, so on APSC it appears to give more than 1:1 magnification. If you go into the equivalence vortex you will just get confused over useless things. The DFA 100mm is a great lens, on ASPC and on FF. You will enjoy it on either camera, or both.
You cannot just multiply 2.8 by 1.5x. Even hardcore equivalists only multiply the EV, not just the aperture number.
07-27-2016, 10:45 AM   #9
Thanks, I am seeing it really only matters if you have both format cameras then it will perform differently on one camera to the other! Thanks again!
---------- Post added 07-27-16 at 11:46 AM ----------
Thanks!
---------- Post added 07-27-16 at 11:47 AM ----------
QuoteOriginally posted by pathdoc Quote
Thanks!
Thanks!
---------- Post added 07-27-16 at 11:48 AM ----------
Thanks!
QuoteOriginally posted by savoche Quote
Thanks!
QuoteOriginally posted by pearsaab Quote
Thanks!
---------- Post added 07-27-16 at 11:49 AM ----------
QuoteOriginally posted by pepperberry farm Quote
Thanks!
07-27-2016, 11:17 AM   #10
UncleVanya's Avatar
Welcome!
07-27-2016, 11:33 AM   #11
Just a warning if you're considering buying it - if you miss focus, usually because the focus point is parked on the edge of the object or on a very thin object, or if you are changing from near to far focus or vice versa, it will rack from one end of its focal range to the other before it settles, and it is one of the louder screwdrive lenses in the Pentax range. However, it is blessed with Quick Shift - get close manually, almost there, then touch up with AF to get it perfect.
07-27-2016, 01:58 PM   #12
Moderator PEG Judges
Kerrowdown's Avatar
Many beat me to it, I'll just say welcome.
07-28-2016, 02:19 PM   #13
Welcome!
Thanks!
---------- Post added 07-28-16 at 03:20 PM ----------
QuoteOriginally posted by Kerrowdown Quote
Thanks!
01-16-2017, 05:46 PM   #14
Welcome!
Thanks!
---------- Post added 01-16-17 at 06:47 PM ----------
Thanks!
Thanks!
100mm, aperture, apsc, camera, cameras, crop factor aps-c, d fa 100mm, dof, equivalence, f/2.8, fa, fa 100mm f/2.8, ff, field, focus, format, full frame lens, length, lens, lenses, macro, magnification, object, pm, post, range, stop, thanks
D FA 100mm F2.8 WR Macro, or DA 35mm f/2.8 Macro Limited? virtualjsk Pentax SLR Lens Discussion 29 12-08-2015 11:31 AM
For Sale - Sold: Pentax D FA 100mm f/2.8 Macro WR *SOLD* Thomas Cantwell Sold Items 4 11-12-2015 03:59 PM
Lens choice - Pentax D FA 100mm f/2.8 WR Macro or Tamron SP 90 mm 2.8 Riverlady Pentax SLR Lens Discussion 33 04-28-2015 01:38 AM
For Sale - Sold: Pentax D FA Macro 100mm f/2.8 WR bonaprof Sold Items 2 09-05-2014 08:54 AM
All times are GMT -7. The time now is 08:18 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
