Originally posted by Aslyfox No problem, that explains all, I was going to but I found a good deal and wife decided I could get it for a combo Christmas and birthday present.
thanks for the suggestion about needing to keep trying to become good with it
Do you think that working with the big guy -150 -450 mm zoom at short and intermediate distance would be helpful or do I need to "stretch it out" to learn ?
I've had mine for over a year now.... I quite like it. Anyway, I was mostly using F*300/4.5 before that.... a quite lite and small 300. Some key thoughts from me are.....
1: Best iq around f8-11
2: it's light transmittance for a given aperture is 1-1.5 stops less then a prime.... so shutter speed goes down or ISO up for a given aperture.... ie. it needs lot's of light.
3. A sling is your best friend
4. higher iso is a better friend then slower shutter speed
5. a mono pod is your next best friend.... or some sort of rest
6. it's a good lens capable of high quality results
7. 450mm on a K3 requires conscious effort for top results (it is 600mm anyhow)
8. K1 loves it
It's not just for small things
