10-03-2016, 05:10 PM   #1
Hello and a question
Hello, just joined the forum. The reason primarily is I want to get back into wildlife photography. I have a 10 year old Pentax K100D with a Pentax DA 55-300mm and the standard 18-55 mm that came with the camera. It only takes up to a 2GB card, which is a limitation. I want to upgrade to a newer Pentax with higher MB capacity and SD card capacity. Also, one that I could use my existing lenses on. What would you'll suggest for a weekend photographer/amateur just to have fun with.
Thanks,
George
10-03-2016, 05:16 PM   #2
With a firmware update, the K100D can accept up to 32 GB SDHC cards.
Anyway, it's quite dated, so I'd absolutely recommend upgrading to a more modern body. The K-S2 is currently the best value in my opinion. You can also go for the K-70 for better image quality if your budget is higher, or the K-50 if you don't want to spend as much.
New pricing should be $499, $649, and $319, respectively. The K-50 is discontinued at authorized dealers, though, so it may run you more.
All three are reviewed in-depth here:
In-Depth Reviews | PentaxForums.com Reviews
10-03-2016, 05:26 PM   #3
I loved my K-50 for a quality amateur body and if you can find a kit on clearance somewhere it should be a bargain, especially if you can find one of the 18-135 kits for a bit of extra oomph.
10-03-2016, 05:46 PM   #4
Welcome to the forums.
10-03-2016, 06:37 PM   #5
GolNat's Avatar
Welcome. Depends on your budget but a K-50 with a nice fast zoom would be a nice combo.
10-03-2016, 09:04 PM - 1 Like   #6
UncleVanya's Avatar
QuoteOriginally posted by gwn7 Quote
Thanks,
George
There is a nice camera database on the site (top navigation bar - cameras) where you can see a lot more detail but here's a partial list of options:
K-30 or K-50 - 16mp "low end" camera (very advanced for "low end")
K-5, K-5ii, K-5iis - 16mp "prosumer" camera. ii and iis are improved versions. iis has no antialiasing filter so it has higher sharpness.
KS-1, KS-2 - 20mp low and midrange cameras. KS-1 is not weather sealed. All other cameras on this list are.
K-3, K-3ii - 24mp "prosumer" camera. ii is improved including pixel shift but it lacks onboard flash opting for onboard gps tracker.
K-70 - latest 24mp "low end" camera, includes pixel shift for high color accuracy and detail.
There are many more models between but those are the ones that I know something about. The K-30 and K-50 are almost the same camera with different styling. The K-5 series is very nice and can take an external battery grip should you wish. The KS series is a bit oddly styled in version 1 and less so in version 2 but still a departure from Pentax norms. Good sensor, nice output in all of these. K3 series is bigger like the K-5 and has the option of a grip. It also offers pixel shift in the version ii, both models have dual sd card slots. K-70 is very new - and has a few video centric features that may be better than the K-3 series but it does not offer all the bells and whistles.
Budget?
All of these work with your existing lenses.
10-03-2016, 09:33 PM   #7
pjv
Proudly Pentaxian
pjv's Avatar
Hi George. Welcome to the Pentax forums. Lots of good advice already given to you, so I will just say welcome and good to have you here.
10-04-2016, 12:42 AM   #8
PEG Moderator
Kerrowdown's Avatar
I'm here late in the day, good replies already, welcome to the forum.
10-04-2016, 02:23 AM   #9
Great responses. Thanks for all of the advice. I'm going to start researching now.
10-04-2016, 02:24 AM   #10
Good to know about the firmware. Thanks
10-05-2016, 05:56 AM   #11
TER-OR's Avatar
Remember the Marketplace here. You can get great values on used gear and be fairly confident the gear has been cared for appropriately.
Welcome aboard!
capacity, card, pentax
Hello, and a question. NightWriter Welcomes and Introductions 11 11-03-2014 08:50 AM
hello and a question liquidlenny Welcomes and Introductions 3 10-26-2014 02:14 AM
A hello and a question about PP Des Welcomes and Introductions 10 02-02-2014 08:41 AM
Hello and a question NeilB Welcomes and Introductions 2 01-28-2009 02:35 PM
Hello and a question Robert Woll Welcomes and Introductions 2 01-25-2009 03:39 PM
All times are GMT -7. The time now is 06:01 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
