Originally posted by rmc63 so I went to the local camera shop and ordered the new 55-300 PLM. When the lens came in, I went to the shop and attached it to the K-3ii and it would not autofocus at all. I had updated the firmware to version 1.10 months ago. Could it be the firmware upgrade didn't take properly? Is the lens just DOA? Has anybody else had this kind of experience with a new lens? I have another one on order and hopefully it will arrive this week.
Thanks, Mark.
Welcome. There are a few Canadian Pentaxians on this forum, including some from Toronto.
You have the correct firmware version 1.10 to operate the PLM lenses. However you might want to confirm that it installed properly by doing the following:
How to check version
[1] Turn ON the camera.
[2] Press MENU button to display MENU screen.
[3] Press the four-way controller right to display [Set-up 4] menu screen.
[4] Select [Firmware Info/Options] in the [Set-up 4] menu then press the four-way controller right.
The firmware version for camera is displayed on the [Firmware Info/Options] screen.
