Originally posted by Craigbob What are the down sides of using an APS-C lens on the K1?
1) In standard-ratio crop mode, you get a 15 megapixel APS-C image. The upside of this trimming is that there is no issue with vignetting, beyond what the lens would give on APS-C anyway.
2) In 1:1 crop mode (available with the latest firmware), you get approximately a 24MP image, IIRC. This does not always crop away ALL the vignetting for some of the wider fields of view.
3) For most if not all crop zoom lenses shot in full frame, there is either a very prominent lens-hood shadow or a very prominent outer dead-black zone at some or all focal lengths.
4) Similar problems exist for the very wide lenses (e.g. the super-compact but very nice DA15/4.0).
If you are the sort of person who shoots in raw and post-processes everything, you can selectively shoot in full frame, overriding crop mode, and cut away the shadow when you do the post work, thereby potentially gaining significant coverage over what auto-crop gives you. If you are planning to mount the image inside an odd-shaped (e.g. oval) frame, this may be of great advantage.
Some of the APS-C lenses, especially those based on earlier film designs, offer so little vignetting that at some distances and apertures it's practically unnoticeable; others are not so lucky.
Even with all this, however, there are a couple of things that need saying:
1) The in-body shake reduction function and image processing are significantly evolved from when (approx) 15MP was a Pentax APS-C standard (though the 16MP K-5 set standards in dynamic range which are still admired today).
2) All of the focus points are inside the APS-C zone, so you're not losing out on the use of any of them by shooting in crop mode.
