03-24-2017, 09:21 AM   #1
PENTAX S2 with S/Nr. 528144
Hello to the Forum,
i am new to this Forum, and i registered for the use of getting some information about the pentax S2 i recently got. It came from Japan, and though it obviosly is NOT a S2 Super, it has an incredibly high Serial Number engraved - 528144
I also tested the Shutter Speed Dial for accuracy, and it works well, so there ist no doubt this Dial is the original part.
My Question is - is this a regular S2 - or is it somebody replaced some parts, mixing an S2 and an S2 Super together...? Can it be that in Japan there were S2 Cameras of late series with these high numbers?
Anyway, i own some different Pentax Cameras, and though i am not a Collector, i definetly like this one S2, it being a rare Collector's Item or not...
Thank You for any Replies!
Greets from Vienna,
tilman
03-24-2017, 10:56 AM   #2
monochrome's Avatar
There is a note in the Serial Number Database for an 'S2' in your SN range. The owner writes it is an 'SB2', a model sold only in Japanese military camps. The owner declares this camera is mechanically an S3, but not labeled as such. Maybe that clears things up - or maybe it adds to the confusion
[Edit] Not helpful. SB2 is engraved on those models per Pentax-SLR.com
03-24-2017, 01:30 PM   #3
PEG Moderator
Kerrowdown's Avatar
Welcome to the forum, sorry I know nothing about these cameras, but I'm sure some one will be along soon with some thoughts.
03-24-2017, 02:43 PM   #4
Digitiser of Film
BigMackCam's Avatar
Moved to "Pentax Film SLR Discussion" forum...
03-24-2017, 03:14 PM   #5
Moe49's Avatar
QuoteOriginally posted by tilman Quote
Edit:
I am going to amend my post here, and say that the OP has a later production S2 based on the S2 S/N range Baard-Einar posted below.
'my original post'
Your S2 looks like an early production 'normal' S2, as it has the older style manual reset exposure counter (the dial on the film advance lever), and it has a 6-digit serial number.
The later production S2's (S2-Supers only?) got the automatic resetting exposure counter from the SV line and 7-digit serial numbers (like the S2-Super pictured below).
I have now seen two S2-Super's with an older style manual reset counter and a 6-digit serial
03-25-2017, 02:18 AM   #6
Thank Yoe, Everybody, for making me feel welcome on this Forum!
Thank You, Moe, for the Reply... and it's a very nice black S2 You have!
My Question is, i know only of S2 Cameras with, well, 6 digits in the Serial No., but all of these are very much lower, mostly 24xxxx. So i thought mine must be a very late model, but it definetily is not a S2 Super. i am confused, and i wonder, if maybe somebody mixed some parts in reassembling this Camera...
Greets,
tilman
03-25-2017, 04:41 AM - 1 Like   #7
Baard-Einar's Avatar
Hi, and welcome to the forum.
The s2 and the s2 super were in the S/N range 223001-636891. Production might have overlapped since the Super was only sold in Japan. But in your case I would assume that your camera has been in for a repair and that the top plate was changed. Spare tops have serial numbers outside of the ordinary production run.
Collecting Pentax is fun, and the S2 by itself is fun due to many versions like Asahi Pentax S2 or H2, Asahiflex S2, Penta Asahiflex S2, Honeywell Heiland Pentax H2 and Honeywell Heiland Pentax H2 Store Demonstrator, then the ones marked Asahi Pentax SB, and the S2 model II called super sold in Japan as well as the SB2. Add to that chrome and black verdions. I've even come across a model engraved for sale via US bases. SB and SB2 were for sale to Japanese defence forces. A fellow collector found one of those in Manila.
Best of luck collecting all of these beauties.
Dont forget to use them.
---------- Post added 03-25-2017 at 12:54 PM ----------
I forgot to add that the S2 came with two types of speed dials, without or with notch for clip-on exposure meter.
The S2 super came with two different types of film counter, old version with manual reset and new version with automatic reset of the film counter.
03-27-2017, 05:03 AM   #8
QuoteOriginally posted by Moe49 Quote
I have seen a S2-Super with an older style manual reset counter and a 6-digit serial
Hi
that is a really high S/n for a S2 Super. maybe this has been serviced with new top?
/Baard-Einar
03-27-2017, 08:45 AM   #9
Moe49's Avatar
QuoteOriginally posted by Baard-Einar Quote
I do not think so ( though I could be wrong ). As evidence: there are three S2-Supers in the PF serial number data base with 7-digit serials in the 17XXXXX range.
Another interesting thing about the S2-Super I have, is that it has the later style top cover. The later style covers do not have two screws flanking the viewfinder window.
03-27-2017, 11:44 AM   #10
I do not think so ( though I could be wrong ). As evidence: there are three S2-Supers in the PF serial number data base with serials in the 7-digit range, 17XXXXX.
Interesting info. According to The Screwmount Guide the S2 Super have the S/N range 423001 - 749000.
But the total number of S2 Super and Sv is 534196, about 52500 are the S2 Super. S/N range for the sv go up to 1985305.
I need to dig deeper into this material.
03-28-2017, 02:08 AM   #11
Yes, Baard-Einar, it is strange indeed. Thank You for digging...
The one S2 i have definetly is not a S2 Super - i can tell from the Speed Dial and the fact that it works well, that is performing as is indicated. So, the interior being a 'normal' S2, maybe someone replaced the Top Plate. But then, there are signs of use on this Camera, of course, but absolutely no signs of it having been opened. Probably, one wouldn't see these signs, but it is strange it looks just like it's never been openened at all.
Well, anyway i bought it because of this unusually high Serial No., but not only for that - i'm glad it works well and happy using it!
Among my other Cameras i have one black and one silver SV, one SP500, one K working and one K that is disassembled, and one AP that works almost perfectly... These old 60's Pentax are just my style, and are fun using.
03-28-2017, 07:26 AM   #12
Moe49's Avatar
Ah ! The SV, my favorite pre-Spotmatic camera for shutter-bugging about with.
03-28-2017, 08:15 AM   #13
I love my SV as well. Mine is just back from Eric's along with my K. I can't wait to get it out and run a roll through it. Maybe this weekend.
03-29-2017, 11:54 PM   #14
I found this on ebay from an Italian seller. The start price is really high in my opinion. But the sn is low, and outside the known range. The ready case also have a neat feature, you can leave the clip-on exposure meter on camera. Ive not seen that before. These old cases seems to crackle and turn to dust.
Moe, comments?
Look at this on eBay KIT ASAHI PENTAX S2 Super 1/1000 Type1 BLACK MINT- ULTRARARE (NOT 4 EVERYONE...) | eBay
03-30-2017, 07:06 AM   #15
Moe49's Avatar
Moe, comments?
Apologies to the OP for the thread hijack
That Italian S2-Super is in superb condition and looks authentic for an early model.
It's S/N 264648 falls into the correct range you quoted from:
If anyone actually mounts the viewfinder clip-on and meter on that camera, dinging up that pristine top cover in the process, ... well they should be beaten sense-less.
cameras, counter, film, forum, h2, honeywell, japan, model, notch, pentax, pentax s2, reset, s2, s2 series no. 528xxx, sale, types, version
DXO NR Prime? Storm Chaser Digital Processing, Software, and Printing 13 01-12-2017 07:39 AM
Why was the High ISO NR a problem on the K3? Culture Pentax K-3 & K-3 II 15 10-09-2015 08:46 PM
nr flashing on top plate geordieman Pentax K-3 & K-3 II 2 08-14-2015 11:41 AM
Pentax K-5, Low level NR testing... JohnBee Pentax K-5 & K-5 II 33 11-05-2010 07:46 AM
Does Pentax applies NR to its RAW files? ManuH Pentax DSLR Discussion 5 05-05-2009 08:13 PM
All times are GMT -7. The time now is 05:16 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
