Originally posted by Pentax Syntax Does the autofocus lens focus well on the K-10? When you focus the K-10 manually with autofocus function on do you get a focus confirmation light and sound? The old lenses work well with autofocus confirmation although one focuses manually. Have you tried the diopter adjustment? You can also get eyepiece magnifiers that clip on to the viewfinder if that is a help.
Thanks for the warm welcome!
I don't wear glasses (unless you count my recent acquisition of +1.25 reading cheaters). Yes, my diopter seems to be well-adjusted, and I can get a sharp focus in the viewfinder. But I've observed that a sharp focus in the viewfinder does not correspond to the same sharp focus point in the resulting image. E.g. the image consistently has its sharp focus point 1cm from the spot I had chosen in my viewfinder focus along a 30cm ruler. I've also experimented with relying on the hexagon focus indicator to try to get a better image focus, but notice that it stays lit over a (small) range of focus, so I'm trying to discern where precisely the best spot is in that range.
Yesterday, I ordered a split-image focus screen for my K10D. When I install that, then hopefully I will be able to more accurately evaluate the focus issues via the viewfinder. I read with great interest the thread on focus screen shims:
Focusingscreen shim - Page 3 - PentaxForums.com
