Originally posted by Maxibear Hi all,
I've been wanting to get back into photography for over 20 years! I decided recently I could afford an entry level DSLR. I purchased a Pentax K-70, I am enjoying learning how all this works again. The DSLRs seem to do almost everything for you, not like the old K1000 which used to drive me spare when i would forget to set the camera correctly before shooting and then getting that sick feeling when you picked up the prints from the photo-shop!!! When I got it right it was worth the heartache of the ones that didn't work. Seems like a life time since that happened.
Now I have a small issue. I read up a little about the DCU V5 that came with the K-70 to see whether or not it was worth while for a beginner like me. long story short, I decided to give it a go. I can't even load the pictures from the files after downloading the camera ! Very frustrating. I'm not a dummy but i'm obviously not savvy enough to get it happening. I did up-date the version 5 to 5.7.2, but still nothing. Files loaded from camera ok I can view in windows, DCU V5 just doesn't open from the folder.....
Hope someone can shed some light.
Maxibear.
G'day Maxibear,
Welcome to the forums. The K70 sounds like an excellent camera and I'm sure once you've gotten over the little software hiccup you'll be good to go.
I'm no real expert with DCU5, but I'll see if I can help get you along the way whilst you wait until the smart people come along to provide some advice. I'm not real sure what you're seeing, so it may assist if you can get some screen grabs to post in the thread.
To start with, is DCU5 opening on your system? If it is, ensure you're in 'Browser' which is identifiable by a button in the top left of the page. If you're in the browser it will be blue.
On the left side of the screen, below where the 'Browser' button is you should see a series of tabs. Ensure the 'Folder' tab is selected. I'm using a Windows system and it will appear the same as the Windows folder view.
If this is working so far then you should be able to select a folder with photos, RAW, JPEG, TIFF files will all work. If I've got it right then a thumbnail of the images in the folder should appear at the bottom of the screen and you can select them from there. To process an image select 'Laboratory' which is the button next to 'Browser'.
Let us know if any of the above has assisted or what you are seeing when you start DCU5.
Tas
