05-01-2018, 02:29 PM   #1
Hi from The Netherlands
Since about a year i own a K-1 which i purchased with the HD PENTAX-D FA 24-70 mm F2.8 ED SDM WR.
Last week i added the HD PENTAX-D FA* 70-200mm F2.8 ED DC AW
The reason i joined this forum is because of an issue i have with the 70-200 lens.
So, first i checked the forum for similar issues and replied to one of the posts:
Tiny circular movement between body and lens when mounted - PentaxForums.com
Hope to find the help i need to solve my problem.
Otherwise i'm one happy Pentaxian.
Cheers,
Jack
05-01-2018, 02:34 PM   #2
Senior Moderator
BigMackCam's Avatar
Welcome to the forums, Jack.
So long as the movement is only rotational, it's really nothing to worry about at all (if you can rock the lens back and forth due to an actual gap between the lens mount and the camera, that's different).
Rotational movement can happen if the locking hole on the lens mount is slightly bigger than the locking pin on the camera, or if there is some amount of lateral "play" in that pin, or even due to tiny manufacturing tolerances on the rear flanges of the lens mount. It's also more likely to happen with certain lens mount finishes (especially those that are highly polished and have absolutely no texture whatsoever, as there's less friction between the camera and lens.
My own Hasselblad HV and about half the lenses I own for it (including my very best Sony Zeiss 24-70 f/2.8) do this. I've never had a problem.
Don't worry about it. Enjoy your fine new lens
05-02-2018, 04:18 PM   #3
MarkJerling's Avatar
Welcome to the forum.
So long as the lens functions correctly, which means the electronic contacts all line up correctly, I don;t think you need to worry.
Kind regards,
Mark
(New Zealand)
05-05-2018, 01:38 AM   #4
PEG Moderator
Kerrowdown's Avatar
QuoteOriginally posted by JackvanS Quote
Welcome from the Highlands of Scotland, sorry I'm not familiar with this lens at all.
05-16-2018, 03:34 AM   #5
Thanks all for reply.
I ordered myself a Vessel crosshead driver (JIS-type), tightened the screws of the cameramount and the play was gone.
It was hardly noticable when tightening but i felt just the tiniest bit of rotation. Did it very gently.
I'm happy, no worries anymore.
Case closed.
05-16-2018, 06:29 AM   #6
Welcome on these forums Jack! Always good to see a fellow dutchman here. Happy shooting with the excellent K1 and good to hear the problem was solved.
Met vriendelijke groet,
05-16-2018, 06:43 AM   #7
Hi Jack!
My wife is from the Netherlands. I've been there for a few years and it is the most beautiful contry on the planet. It really gets my creative juices going for photography.
05-18-2018, 01:47 PM   #8
pjv
Otis Memorial Pentaxian
pjv's Avatar
Hi and welcome from Australia Jack.
f2.8, forum, hd, lens, pentax-d
hi there from the netherlands gerwinvis Welcomes and Introductions 3 01-16-2017 01:42 AM
Hi from the Netherlands Tiger_SEnior Welcomes and Introductions 7 02-09-2014 02:07 PM
Hi from the Netherlands nickvdzwan Welcomes and Introductions 7 03-04-2013 08:45 AM
Hi from a snow Netherlands gijspossel Welcomes and Introductions 2 01-16-2013 03:32 AM
From The Netherlands comes: Hi! Ghanzer Welcomes and Introductions 2 08-12-2010 09:12 AM
All times are GMT -7. The time now is 10:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
