Originally posted by Skox I have many Helios 44 wich are dreadful useless performers, and a few of them wich are real optical gems
I own most (perhaps all?) Helios-44 variants, and several copies of certain variants. There are things to consider about these lenses:
Firstly, with Soviet lenses, you have to make sure you are comparing the
exact same model, from the same era and factory of production. For example, its pretty safe to compare two 1978 Helios-44-2 lenses from the KMZ factory and expect to get the same optics, same coatings, same build quality and internal finishing, with only minor sample variation. They should perform more or less equally. But if you compare one of those to a Helios-44 manufactured ten years earlier by a different factory, one with more diaphragm blades, different coatings, or perhaps an entirely different model with the same basic optical formula - such as the Helios-44M or 44M-7 - all bets are off. Different factories even used up remaining parts from different eras for continued output of certain models for many years, and at different rates. These aren't sample variations in the classic sense. You almost need to treat them as separate lenses sharing the same optical formula. In this sense, vintage Soviet lenses can be very different from those produced in Japan (for instance).
Secondly, you have to consider that a very large number of vintage Soviet lenses (and, I'd suspect, non-Soviet too) have been serviced since they were first produced... often numerous times, and occasionally by less than scrupulous technicians (in some cases, I hesitate to even use that word - "butchers" might be more fitting). Many have been poorly reassembled, in some cases using parts and optical elements from other lenses, with coatings missing or removed through cleaning / polishing, even sometimes with key elements reversed during reassembly (!).
So, when drawing conclusions about a specific Helios-44 variant, you need to look at your own results and sample size, and consider those in context with the majority of opinions from other users. Only then can you (a) validate or invalidate your own findings, and (b) form a reasonably accurate appreciation of that specific variant
Originally posted by Skox Please have a look at this link.
Thanks for the link
With respect, I think a good deal of that article is trying rather too hard to be high-brow and "artsy".
The definition I can relate to - though I've not heard "plasticity" used to describe it before - is subject-to-background separation due to depth of field, and the associated rendering qualities of in and out-of-focus areas (and the transitions therein), contributing to the "3D" effect. But, I'd suggest that sample variation between otherwise identical lens models is typically insufficient to have material impact on those aspects of rendering. Take ten different copies of the Pentax M50/1.7, for example, and you might find some tiny differences in performance; but the level of subject-to-background separation at a particular aperture and distance will be near-enough identical, as will the rendering of in- and out-of-focus areas.
I've never heard someone use the term "plasticity" before in relation to photography. Is it really in widespread use with professionals, as that article suggests?
