Show Printable Version 4 Likes Search this Thread
10-12-2019, 01:04 PM   #16
Kevin B123's Avatar
Welcome to the forum.
The performance and IQ of the 28-105 really is very good. It vignettes a bit, and that is easily corrected to the point that I don't even notice it, I import with lens corrections on and it's gone. I think it a must have for general work, then you need an actual reason to take it off, i.e. wider faster etc.
Good luck with your choice.
10-12-2019, 01:46 PM   #17
QuoteOriginally posted by lunarpassion Quote
I am looking at purchasing the K1. Is the kit lens 28-105 worth it or should what would be another good walk around lens?
I'm absolutely happy with this lens on my K1-II. It's sharp, it's weather sealed, it gives nice colours, it's not big or heavy. Great walk around lens.
10-12-2019, 02:53 PM   #18
When I got my K1 in May 2016 I got the 28-105 with it. It is much more than a "kit" lens.
10-12-2019, 09:55 PM   #19
kiwi_jono's Avatar
Welcome!
I'm not sure on your experience , but as Adam says it does depends on what and where you shoot, however I have been pleasantly surprised with the DFA 28-105 on my K-1. For the money its got pretty good Image Quality, is relatively compact with has weather resistance. If you like to carry your gear around a lot its a very a useful lens.
However no lens can do everything (like macro, ultra wide lens, long telephoto, shallow depth photography etc) - welcome to the world of LBA (lens buying addiction)!
10-13-2019, 11:00 AM   #20
Master of the obvious
savoche's Avatar
Welcome aboard!
I find the 28-105 to be an excellent walk-around lens (or in my case, travel lens). It has a very useful zoom range on the K-1 and very good image quality - and is compact for what it is. It is certainly a lot better than what you'd normally associate with the term "kit lens". If you want better you would have to go for the DFA24-70 (truly excellent, but big and expensive) or fixed focal length lenses.
10-14-2019, 12:47 AM   #21
dave_roe's Avatar
I like my 28-105. It is working as a good walk around lens.
The focal length does leave a little to be desired and would like something a little wider for tight spaces. Overall I am more than happy with the lens.
10-14-2019, 01:21 AM   #22
welcome to the forum. I think Pentax is worth the try.
10-14-2019, 08:45 AM   #23
Robin's Avatar
QuoteOriginally posted by dave_roe Quote
I remember when 28mm was wide angle! . But personally I find that an ultra wide prime is better for the tight spaces, as you tend to get less distortion.
10-14-2019, 08:52 AM   #24
Seeker of Knowledge
aslyfox's Avatar
welcome
as you have discovered lots of friendly members and knowledge here at the forums
since you are in the U S you do have the option of renting equipment before buying:
https://www.pentaxforums.com/forums/137-photographic-industry-professionals/...ml#post4542890
10-14-2019, 05:01 PM   #25
wstruth's Avatar
Welcome to the forums! The K-1 and 28-105 is a perfect combination well worth it and it will provide heaps of enjoyment!
lens
D-FA 28-105mm lens vs. older FA 28-105mm lenses. Anyone? 6BQ5 Pentax SLR Lens Discussion 14 03-16-2018 06:57 PM
Kansas Rep. Pete DeGraaf: Getting pregnant from rape is just like getting a flat tire deadwolfbones General Talk 15 06-02-2011 09:15 AM
All times are GMT -7. The time now is 01:21 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
