Originally posted by lowmjac2 Bought a K-1 in 2020, did I make a mistake?
Originally posted by lowmjac2 I'm somewhat of a casual photographer and it seems like I'm limited to either expensive first hand Pentax glass (DFA 24-70 2.8, DFA* 70-200 2.8), or older full frame 3rd party glass (Tamron 27-75 2.8, Tamron 70-200 2.8).
Welcome to Pentax Forums!
The K-1 is a great camera. Do you have any Pentax lenses at this moment?
As a casual photographer, I think you have many choices for useful, quality lenses. For example, see this list:
Pentax K-1 - Lens Compatibility | PentaxForums.com
For specifications and user reviews of specific lenses, you might wish to look at the
world's most comprehensive Pentax lens review database:
https://www.pentaxforums.com/lensreviews/
As an example of the possibilities, you could get the
HD Pentax-D FA 28-105mm zoom lens, as mentioned above. For more versatility, add to that a couple of relatively low-cost, wide-aperture prime lenses (i.e., single focal length) such as the wide-angle
HD Pentax-FA 35mm f/2 and a lightweight
'normal' 50mm. Or, you could opt for one of the fabulous FA Limited lenses in 31, 43, or 77 mm, albeit for more money. There is also an almost unlimited selection of older lenses that work well on the K-1.
The newest modern wide-aperture lenses generally offer exceptional optical qualities -- the HD Pentax-D FA* 50mm f/1.4 is a superlative example -- but if your budget is somewhat constrained, there are plenty of other options.
Second-hand lenses are often available, either through the Pentax Forums Marketplace, or from reputable online retailers that carry used gear. Even the more recent lenses appear on the used market occasionally.
I'd recommend that a bit more research and consideration of your needs and possible options would be useful.
- Craig
