Originally posted by Steve Verrall Hi all,
I am not a Pentax or MF shooter, but I do shoot on the Nikon Z7 presently and particularly enjoy using the 19mm f/4 PC-E.
The reason I have joined the forum is that I have purchased a Pentax 55mm f/4 6x7 lens and also a Pentax 645 35mm f/3.5 lens.
On the way but not arrived yet are the Fotodiox tilt/shift adaptors for P645 to Z and also the P67 to Z.
Depending on the useful shift available in each case I expect to be able to make nice panoramas with a final FOV in the equivalent 35mm FF range 22mm to 30mm with these lenses and the adaptors (if I have got my numbers right!)
A bit late unfortunately, but I have now learned (from this forum) that the 67 55mm is a more recent and notably better version than the 6x7 55, so one of those is on the way from Japan.
Anyway I will start searching the forum to see if others are putting these lenses to the same use as I plan to do and get a feel for the results that they are achieving.
When I do start my own shooting I will post some results for those others that might be interested.
Steve.
Hi Steve, I saw your review of the Tilt/Shift Z7 adaptor on the Fotodiox site and found you here on the Pentax forum...
I am also interested in using Pentax 645 lenses with the Fotodiox adaptor and wanted to get your overall opinion on it now that you have had it for a while please?
Thanks, Don
