6 Days Ago   #1
Janet
Hi there,
Iím desperately trying to find a replacement neck strap for my Pentax Papilio Binoculars but without success. Any ideas where I could find one? It is a clip in style fitting.
Thanks guys
6 Days Ago   #2
35mmfilmfan's Avatar
Can you post an image of the actual attachment on the bins, please ? Your description is a little vague.
6 Days Ago   #3
SharkyCA's Avatar
QuoteOriginally posted by Bearsrus Quote
Hi there,
Thanks guys
Pentax Shock Absorbing Binocular Harness 85225 B&H Photo Video
5 Days Ago   #4
QuoteOriginally posted by 35mmfilmfan Quote
Hi, I've attached a link below, thanks.
Google Image Result for https://www.bestbinocularsreviews.com/images/binoculars/Pentax/Pentax-Papilio-85x21-Binoculars-NeckStrapConnector-Large.jpg
4 Days Ago   #5
Thanks for that - must admit I have never seen an attachment of that nature before. Unfortunately, the suggestion made by @SharkyCA does not appear to fit, and I have (as I am sure you have yourself) had no luck with on-line searches for anything even approaching your requirements. I wonder, is there sufficient of the original strap left to consider splicing the end fitments to a new strap ? Also, have you tried Ricoh / Pentax spares - even if they don't have it in stock, they may be able to suggest a supplier. I did consider suggesting a work-around of a cable tie with a D-ring on it, around the lens barrel, to attach another style of strap, but from the pictures it seems there is insufficient space to do this, and it would not aesthetically enhance the binoculars !
Good luck with this.
4 Days Ago   #6
Gosh, seems like it's been discontinued for awhile and no one has any stock left AFAICT.
This is what you want tho, so you can contionue your own search: Pentax Neck Strap for UCF WR Binoculars 69354
2 Days Ago   #7
PEG Moderator
Kerrowdown's Avatar
Welcome to the forum, good luck with your search, I'm unable to help as never seen connectors like that before.
People Searching for Sister Janet Bob Harris Post Your Photos! 4 10-15-2014 03:28 PM
Landscape Djanet. Algeria. akli Pentax K-3 Photo Contest 0 05-05-2014 10:27 AM
Nature Janet Foss shifter Post Your Photos! 0 09-25-2011 03:18 AM
All times are GMT -7. The time now is 04:35 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
