2 Days Ago   #1
Spring issues
Hello Pentax peeps.
After a few weeks as a Pentax owner (35mm), I've just been made aware of a little problem.
On my Pentax ME, the advance lever won't remain in the closed position.
It winds perfectly and doesn't have any other issues but is not held in a closed position. It's very easy just to pull it out a little and not spring back.
Just a little while ago, I read something from a guy that had the same problem:
'The shutter, though, seemed fine as did the electronics and meter display. I knew what this meant: the “click spring” had broken off inside. The purpose of this spring is to secure the wind-on lever close to the camera body to, firstly, switch off the meter and, secondly, prevent accidental partial wind-on.'
So firstly, how easy is it to find a replacement spring, and more importantly, how easy is it to replace?
Is it something I can do myself or do I need an expert?
2 Days Ago   #2
MikeMcE's Avatar
The detent if I remember correctly is a bent hardened part, not fixed, without that part. The broken part can float around, and can create havoc , usually locking the counter. It can jam anytime or anything. Top cover removal is basic, LH cap screw on advance lever, r/w knob, removes rings and screws, lift off.
Hang up and DRIVE!
2 Days Ago   #3
Seeker of Knowledge
aslyfox's Avatar
Welcome to the forums
you will find friendly members and a lot of knowledge here
if one of our members can't help you out, perhaps you might contact:
UK
John Pye Technical (Authorized to perform warranty service)
Johnsons Photopia Ltd (Ceased operations. Former authorized service center)
Harrow Technical (Film cameras and lenses) (Ceased operations)
Luton Camera Repair Services Ltd. (can service digital)
A.M. Technical Services (London area, can service digital)
GRES (Surrey, 645 and more)
Don Clark Camera Repairs Ltd (Gloucestershire)
Asahi Photo (Middlesex, film and digital)
Read more at: https://www.pentaxforums.com/forums/189-repairs-warranty-service/316284-pent...#ixzz6eTepBJh8
follow the above link to find active links
good luck
2 Days Ago   #4
I should have said, when I was inspecting under the base plate, a piece of metal did drop out, the same shape as the one that guy I mentioned had:
"Pentax ME* – Full frame" Pentax ME* – Full frame
Sadly, I no longer have it.
2 Days Ago   #5
QuoteOriginally posted by MikeMcE Quote
Hang up and DRIVE!
What about the shutter release button?
2 Days Ago   #6
MikeMcE's Avatar
QuoteOriginally posted by SnappySteve Quote
Selector dial and button remain with top cover.
Hang up and DRIVE!
1 Day Ago   #7
PEG Moderator
Kerrowdown's Avatar
Welcome aboard hope you get your issues resolved quickly
issues, lever, meter, pentax, position
Any historic or known issues sigma DC lens (18-125mm) on a K10? marcusBMG Troubleshooting and Beginner Help 5 03-06-2019 04:49 PM
Does anyone have K3 focus issues? Alnjpn Troubleshooting and Beginner Help 12 02-26-2019 07:50 PM
Two second timer, Cactus V6ii, and K-S2 Issues FozzFoster Flashes, Lighting, and Studio 6 12-15-2018 07:17 AM
Spring Colors - Before Spring Storm milmo Monthly Photo Contests 0 04-23-2014 09:43 PM
All Hands on Deck...Spring Has Spring!! VaughnA Post Your Photos! 6 04-18-2009 01:43 PM
All times are GMT -7. The time now is 06:00 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
