Right , all that does not make any sense. I do not have K-x any more but from memories and experience with other Pentaxes.
The flash release button is purely mechanical , nothing to do with batteries or firmware.
The camera is not bricked, the bricked = totally dead.
There is an "INFO" button on the back of the camera , you can completely disengage / disable the back LCD screen.
There is a manual for K-x in-there , please download it and have a look:
Operation Manuals Download : Support & Service | RICOH IMAGING
---------- Post added 03-08-21 at 10:04 ----------
Originally posted by VSTAR Someone can correct me if I am not correct....can’t Harry use an SD card that is formatted in his computer and not in the camera? The camera is simply looking for the BIN file??
If I am correct, then Harry, put an SD card in your computer, right click it, hit format for the card. Then download the Ricoh firmware file, unzip, transfer necessary file to the card. Then card into the camera and follow instructions on line.
Have you done that yet????
yes , you can format SD card on PC or Mac computer.
just make sure that firmware data is unzipped and the wdc206b.bin file is place into the root directory on your SD card.
Follow the instructions:
Latest K-x Firmware Update : Software Downloads | RICOH IMAGING
PLESE NOTE : there is mistake in-there , the :
"the route directory" means ( should be ) " the root directory"
