Originally posted by Vigman Just found the spreadsheet I made of what was in the metal cases!
Obviously the macro lens and manual/ auto adapter were best ( offered £550) for the macro lens years ago
Pentax Z1 instruction manual
Pentax P50 instruction manual
Aico zoom slide duplicator
Pentax MX body
1:19 50mm Auto Chinon
Pentax P50 body
Vivitar 28-105mm 1:28-3.8 macro focusing zoom
SMC Pentax FA 1:28 100mm Macro unit
Pentax -F SMC 17X AF adapter
Sigma zoom AF-1 1:4.5-5.6 f=75-300mm
Panagor light meter
Pentax MZ-5N instruction manual
Pentax Z1 broken battery compartment catch
Pentax 28-105 lens
SCA 312 auto flash
ScA 374 auto flash
Makinon auto 135mm 1:28 lens
Tamron 1:25 90 mm (tatty)
Vivitar auto extension tube 36mm
Vivitar auto extension tube 20mm
Vivitar auto extension tube 12mm
Tokina 135mm
Pentax M 50mm
Sigma APO 75-300mm
Cased Mamiya 645 BODY ONLY + extra back & instruction manual
3 x aluminium camera cases
Not bad for £50 / $40 !
Vigman
There are indeed some nice treasures in those aluminium cases:
If it is the Pentax M50/1,7 (or the M50/1,4) those are very good, the M50/1,7 is seen by some as one of the best 50mm lenses Pentax ever made but of course
green button mode only in M-Mode of your K-x and preset aperture.
As you mentioned, the FA100/2,8 macro was a steal, it is optically as good as the modern D-FA100macro but more robust.
I had the F-version but I wanted quickshift so I sold it for the D-FA100WR-macro.
The Pentax 28-105 exists as 3 different FA versions, one being larger and quite heavy because it has the powerzoom (PZ).
The only DSLR which offered PZ was the early *ist-D
but your Z1 (and the desired Z1P) analog 35mm film-Pentax has it, it was introduced with those as was MFT
The light FA28-105/3.2-4,5 AL/IF could have been a great lens but it was made that light that when it hits the ends it does so with too much power and misaligns (goes out of focus). It was the only Pentax-zoom with ghostless-SMC-coating which otherwise was reserved only to the FA-limited lenses in those days (as far as I remember)
The
Tamron 90/2,5 macro is a fantastic Tamron Adaptall lens.
If it has the
Adaptall-2 PK/A adapter it has A-contacts which makes it even more special because those rare adapters allow A-mode and because being rare are highly sought after. If with the old adapter without A-contacts M-Mode with green button still makes this lens a steal.
Those two Sigma AF Zooms depends which ones. The APO usually is the better one, I daubt it is the late OS version which is very good.
If the Mamiya 645 is working it could bring enough to buy a decent Pentax K5 to make the best out of all these lenses.
Same for the MX.
The [
https://www.pentaxforums.com/lensreviews/Pentax-Rear-Teleconverter-F-1.7x-Au...ter.html]F-1,7 x AF Adapter[/url] is nice as well.
I am not that much a fan of those converterts, I used the DA 1,4 rear-converter sometimes but find "plugging it in" too much work (lids/protection)
and it steals light and some sharpness. But for the DA*300 it seems to work great, not so much with my DA55-300PLM.
You could sell one of the macro primes (check the Tamron for funghus etc, if alright I would keep this one)
and enhance your Pentax equipment quite a bit.
Good luck and enjoy.
