Originally posted by Bob 256 Hello Anton and welcome,
As wadge22 mentioned, a DSLR might be an alternative for you. You can buy a pretty good digital SLR for the cost of a scanner. No more needs for film - just recharging a battery though you still need a means of printing from files if that's what you want. In addition to taking photos, it can be used to "scan" your existing slides or negatives using a copy setup.
Film has some advantages too (one in that you can continue to use your existing cameras and their lenses) and if you go that route, you might want to look at eBay for scanners. Keep in mind that the "native" resolution is what counts, not the advertised resolution (which might be drawn from interpolation of a lower resolution scan). Scanning is not too involved but can take some time depending on the speed of your scanner. I have a lot of film and the time factor is what keeps me from doing all the scans needed. With digital, it's done when you snap the picture (and SD cards hold a lot of photos).
In either case, you end up with a digital file and go from there with your chosen method of viewing or printing. With either, it helps to have some form of photo-processing software to allow you to improve on those files and make any needed corrections (color, contrast, etc.)
Thanks a lot!
I just bought a Minolta x700 camera for 20 Euros which I fixed and I already found reflecta proscan 7200 (resolution of 3600 dpi ) scanner that was gathering dust, but I still do not know what is actually better :
- scan at home.
- scan at lab
- or direct print in lab (in lab they told me they scan it anyway before printing)
I think I give it a try and see the differences.
