Originally posted by Visker I was getting towards these same conclusions - what an irony that they have this protective tooth (fin) in place when there is no aperture control fin - the aperture is fixed at f8In response to others - it seems that the generalisation is false. I have 2 Sigma K mounts and they have the same problem.
What generalisation is it that's false? As far as I know, any K-mount lens
made by Pentax (which is from 1975 onwards) will fit any Pentax K-mount camera with a few oddball exceptions. With some combinations there will be limited functionality, but all will fit and allow a photo to be taken.
It is
not true however that
any nominally K-mount lens made by
anybody will fit
any K-mount camera made by Pentax or anybody else. Numerous 3rd party lenses, nominally K-mount, have been made by 3d parties, of various quality, and quite a few nominally K-mount cameras have been made by other makers because the basic K-mount "standard" is open-source. At the same time the K-mount itself has evolved over time into something significantly more complex than it was in 1975. A bit of inside knowledge is needed to know whether A will fit B, if A and B were made by different companies at separate times - this forum is the type of place to get that sort of knowledge.
For example Ricoh (long before it became Pentax's parent) were making their own nominally K-mount SLRs and corresponding lenses around 1980, but don't even think about putting one of those old Ricoh lenses on a modern Pentax camera.
That Pentax have managed to keep lens compatibility within their own brand since 1975 is quite a technical achievement. No other camera maker has managed to do this for such a long time right up to the present, although Nikon kept up a long period of back-compatibility until they introduced their mirrorless cameras. However don't expect the same level of compatibilty with third party equipment, because the third party lens makers are inclined to make economies by minimising the changes needed between the different mounts they are selling for, which might have been OK for a while at the time.
Originally posted by Sandy Hancock There is a long history of Sigma making K-mount lenses. I have owned several over the years, and still have the 35/1.4 Art, with no compatibility issues at all.
Sigma are one of the better independent lens makers, but I have a manual 75-250mm made around 1985 which fits my LX and my K-1, but does not fit a K10-D. It is the usual problem, same as the OP's, that the light baffle by the aperture lever is too long and prevents the bayonet from twisting up fully. I guess Sigma made it as long as it is in order to cover several bases so to speak. The simplest solution is to remove it if you can get the screws undone.
