Thanks Carola and Alvin,
I'll be trying out the different ways and let you know how it goes. As far as I know I have a P-TTL flash, but not a Pentax (Digital Concepts 736AF). It won't be anywhere near as good as the originals but it adjusts fine shooting straight on the subject. It's bounce flash that baffles me a little...
Carol, how does the 540 flash adjust for bounce? Do you have to change settings in any way for it?
Thanks for your input.
Ash.
Originally posted by Alvin Hi there, Ash!
Welcome to the forums! I have several old M and K series lenses and a K100D. The on-board flash will fire at full power no matter what, so to compensate, I had to set my shutter for 1/180 and then adjust the aperture accordingly (somewhere in the range of f8 to f16 if further or closer respectively).
I heard in order to get around this problem, you will need to purchase an external flash that can support P-TTL, so that is the AF360 or AF540 flash. I'll look for the thread and post it up here later on, so you can browse through it.
In the meantime, have fun!
