Originally posted by Adam We could just plot your location based on IP, but I believe that that would be a privacy violation. In many cases, IP pinpoints the location of your house/apartment - just go on Google Maps and check.
I don't think I will be proceeding with the ZIP code idea, either, simply so that the map feature remains on an opt-in basis.
The only reason I was asking was because of simplicity to plot.
I woud be interested in seeing some form of map, even if it only showed the global distribution of members, because It would be curious to know where most pentax shooters reside.
I am not worried about seeing them in public, bcecause i can count the number of times I have seen a pentax shooter. But that is a different issue.
However, I can see one interesting use of an interactive map, and this is associated with trips etc. If you had a map by perhaps state, or some region, and clicked on it, to send a PM to members living nearby, for advise on travel it would be useful, Not sure how many would appreciate it though, as I have only had limited response, as have others, in travel tips in certain areas
