01-04-2011, 11:13 AM   #1
Reputation for relative newcomers
I'm trying to understand how the reputation system should work; and in particular, why my "Reputation Power" is zero. I've been here about 6 months and have around 60 posts.
Until this morning, my Reputation was also zero. Presumably that's because nobody likes what I write, except for one guy who also had a Reputation Power of zero so he doesn't count. (I've since boosted my rep by posting serial numbers for every bit of Pentax kit I own, so it's no longer zero.) In the same way, presumably there's no point in me clicking "like" links for other people until my Reputation Power changes.
Is this what you'd expect? I'm not too bothered by the rep itself, but I found an oldish post which suggested that Reputation Power should increase to 1 after 25 posts, so I am wondering if there is some fault somewhere. If this is how it's supposed to work, it seems an uphill struggle for newcomers.
Edit: to expand on that... As a relative newcomer, I can't presume to help experts. I do sometimes feel I can help other newcomers, especially when they are wrestling with the same problems I had. (Experts sometimes take for granted the very thing the newcomer doesn't yet get.) However, I'm obviously on a hiding to nothing here, because newcomers are unlikely to understand the rep etiquette, and even if they do, they'll inevitably have zero Reputation Power. So we don't get rewarded for helping the very people who need help the most.
I'm not sure what the solution is. I appreciate you can't give newcomers an initial Reputation Power without risking ballot-stuffing behaviour. I don't know whether "likes" given out when RP is zero, start to count retrospectively when RP increases to one; if they do it would help, but not much because many users will disappear forever when their problem is solved, and so never reach 100 posts (or however many are now needed for RP).
01-04-2011, 12:12 PM   #2
All reputation power is is the number of rep points that you give with each like click. You need at least 10 rep points in order to add to others' scores; however, your comments and likes will still be visible by others even now.
For every 1000 posts, 100 rep, or year of membership after that, you gain 1 rep power. Be advised that this is likely going to be dramatically decreased in the future, so that new members have a power of 1 and senior members have a power of 2.
01-05-2011, 01:33 PM   #3
Surely you mean "dramatically increased"? Currently new members have a power of 0, so 1 is an increase.
It sounds like the answer to my question is, "Yes, rep power should still be 0 after 60 posts and 6 months membership". Thanks for the reply.
01-05-2011, 01:48 PM   #4
No, I meant decreased so that the spread is the much smaller. See above for details on how rep power is calculated.
count, experts, newcomers, people, posts, power, rep, reputation, zero
Expensive is relative gebco Photographic Technique 8 05-21-2010 04:29 AM
Question about object placement relative to height jct us101 Photographic Technique 9 04-15-2010 06:49 PM
Question Relative field width on the forum? emr Site Suggestions and Help 4 01-06-2010 01:06 PM
Relative prices of different liquids Vylen General Talk 20 12-23-2009 01:18 PM
Professional samples for newcomers D4rknezz Photographic Technique 23 09-27-2009 07:06 PM
All times are GMT -7. The time now is 07:14 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
