02-01-2011, 08:18 AM   #1
lavascript's Avatar
Serial number database: Mfr date
The manufacture date of the body is in the EXIF that can be seen with PhotoME or exiftool. Maybe there should be a field for it in the SN database?
02-01-2011, 10:55 AM   #2
Most people have no idea about that though, so we can't require this information. If available, it should be put in the descriptn field. I've seen some people do this already!
02-01-2011, 01:20 PM   #3
lavascript's Avatar
Myself included
No, I don't think it should be required, but maybe an optional field?
02-01-2011, 01:30 PM   #4
I'm going to leave it as it is right now and leave the description field open to any other interesting tidbits you might have. Lots of information could have its own fields- but if most of them aren't used, then they actually hurt visibility more than they contribute.
02-01-2011, 01:40 PM   #5
dgaies's Avatar
I had an idea that is probably not worth the effort, but I'm just thinking out loud at the moment. What if when entering the information into the fields, you could also upload a sample picture from the camera. The picture wouldn't be used or saved for anything other than to extract the date of manufacturer for the camera body from the EXIF data.
Again, normally I would discount my idea as a waste of time and effort, but in this specific case there is a lot of interest in determining a correlation of variables to sensor stains, and the date of manufacturer is very likely to be an important one.
02-01-2011, 01:49 PM   #6
jhead doesn't support the extraction of proprietary exif info, so I wouldn't know how to implement that. Would otherwise be a nice idea, but another problem would be that the post limit is set to 6Mb, and most full-size images with unmodified exif headers are larger than that.
02-01-2011, 02:00 PM   #7
dgaies's Avatar
I suppose the second issue could be addressed by setting the camera to a smaller file (2-6 MP), which would keep the file size small enough. But at that point it takes away some of the ease of this potential method as it requires the user to specifically change settings and then take a picture for the sole purpose of determining the date. Plus, if there are technical issues with extracting proprietary exif data, then it's all a moot point anyway
02-01-2011, 03:03 PM   #8
lavascript's Avatar
Well, Adam, if you think you might want to implement something like that, I could probably script exiftool to run on the back end and extract the date and populate a field in the form. My name is this for a reason.
PM me if you want me to take a look.
02-01-2011, 03:26 PM   #9
If you can make a C program that does that, then yeah, I could definitely use it to implement this feature.
database, date
Lens Serial Number Database Ole Pentax SLR Lens Discussion 63 06-24-2019 01:47 AM
DA* 16-50mm Serial Number Database. Buddha Jones Pentax SLR Lens Discussion 528 06-13-2012 01:11 AM
K1000 Serial Number Database Ole Pentax Film SLR Discussion 233 02-26-2012 10:30 AM
Error Serial Number Database editing errors indytax Site Suggestions and Help 1 01-31-2011 08:06 PM
Serial Number Database royal07 Pentax SLR Lens Discussion 1 10-15-2010 05:04 PM
All times are GMT -7. The time now is 03:22 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
