Originally posted by carpents I might change the subject of the resolution tests to include (per *isteve) something with more discernable detail, like blades of grass or a USAF test chart.
Any other recommendations?
Just don't overdo it. We know, approximately the theoretical limit of the sensor and if you get a result showing the approx the estimated 28% increase (if I get it right) in linear resolution that should be enough. It is a camera test and not a lens test, after all.
The increased possibilities to crop are important to many (yes, I often crop pictures). The K10D also gets a little more picky about the lens if the higher resolution is to give any advantage compared to the 6MP sensors. The kit lens, well... I say nothing.
Also remember that *isteve shot a freak'n atlas when comparing lenses, giving basically zero information about the absolute resolution possible...
He was pretty hard to convince when I suggested he should have added the center piece of a USAF chart to the test. It's easily done if you focus carefully.
regards,
