Updated description and pics for Jupiter 11A
Jupiter 11A 4/135 135mm F4 Lens Reviews - Russian and Zenitar Lenses - Pentax Lens Review Database
I used noparse so you can simply copy and paste without losing bbcode
135mm f4 based on Carl Zeiss "sonnar" prewar design. Made by Kazan Optical-Mechanical Factory KOMZ see [url=http://cameras.alfredklomp.com/logos/ ] here[/url]. I think, like the helios's, this optical design was made in a variety of places see eg Tair 11A and other 135's.
[i]Typically available with M42 screw mount. In practice, the design of the mount is that of a T-mount see pics. It is straightforward to unscrew the grub screws and replace an M42 with the exterior/bayonet part of a PK T-mount (although I should caution there may be a bit of trial and error/mix and match in getting a good fit). I had no problem with infinity focus. For practical purposes this can be regarded as a swappable T-mount, and this is the case with other Russian lenses as well eg the
[url= https://www.pentaxforums.com/userreviews/tair-tair3-fs-ta-1048-p3-1060-c-4-5-300.html ] Tair 300 [/url] listed by DME, Tair 11A et al.[/i]
[table]
Optics:| 4 elements/3 groups.
Aperture range:| f4-22, no clicks; to operate like a preset press the aperture ring down and rotate to restrict the aperture range.
Iris:| 12 blade iris.
Focus:| just shy of a full 360 rotation.
CFD:| ~ 1m or a little under.
Filter:|52mm, normally supplied with screw in metal hood that inverts for storage.
Length:| ~ 9.5cm, max ~ 12cm; with hood ~18cm.
Weight:| ~ 390g lens only.
[/table]
Reason: correct KMZ to KOMZ
