Originally posted by dibat Hello,
your system for attaching photos did not allow me to upload photos larger than 1280x800px while in the contest rules stated that it is permitted to 1280x1024px. Also when uploading the image your system apply excessive compression, despite the small size of the file. As a result, the quality was horrible!
thank you
If you were able to upload a photo with the long side at 1280 and the short side is 800 then that is most probably caused by your aspect ratio. If you increased the short side to 1024, the long side would be too big.
Hope this helps.
