01-05-2015, 08:39 PM   #1
NicoleC's Avatar
Minor touch incompatibility issue
This falls under the category of 'annoyance' more than bug, and occurs when you are using the site on a touch screen. When you click on the drop down menus it registers as a 'search,' I think. So, immediately after selecting your submenu item (for example, Browse New Posts), you get an error saying you have to wait 3 seconds between searches instead of seeing the requested page. Immediately reloading the page then works.
I don't experience this on a non-touch device using the same browser.
01-05-2015, 10:55 PM   #2
Can you be more specific- which menus are you referring to?
01-06-2015, 05:56 AM   #3
NicoleC's Avatar
The only one I ever do is the Forum -> Browse New Posts option.
01-06-2015, 06:39 AM   #4
Arjay Bee's Avatar
Adam, I get the same on my windows tablet if I tap on the notification for a liked post. I get the warning that I need to wait for 3secs between searches. If I go to the my activity drop down and tap on my liked posts the liked post opens no problem.... as op says a minor annoyance.
01-06-2015, 10:47 AM   #5
Tom S.'s Avatar
Are you both using Windows based tablets? I ask because I have a Android tablet that works fine, so it might be a Windows problem.
01-06-2015, 04:30 PM   #6
NicoleC's Avatar
WebKit browsers handle touch events differently than the (relatively new) W3C standard. IE 10/11 uses the standard. So if the site has touch coding specific to WebKit, it will work on Chrome and Safari, but not 100% on IE. Until WebKit browsers incorporate the standards, coding for both is required.
None of which is unusual; code in-the-wild is always ahead whatever the final standard will be, there's a mess and eventually it gets straightened out, but developers and QA tester get gray hairs trying to make it all work.
I am so glad I'm a RETIRED web programmer. I have enough gray hair.
Touch Events
01-06-2015, 05:31 PM   #7
Arjay Bee's Avatar
Yup, I'm on a windows 8.1 HP Elite Pad.
I suspected it was a code handling glitch so I just use the workaround as above.
01-06-2015, 11:05 PM   #8
I tested this using a windows 8.1 touchscreen laptop and found the issue to only occur in IE (11). I've now fixed it- let me know if you guys are still having the problem in other browsers.
page, touch
All times are GMT -7. The time now is 08:38 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
