Originally posted by Adam If you click on the icon in the upper-right corner of the editor, you can manually edit the bbcode tags that the WYSIWYG editor generates. HTML is not available for security reasons, among others.
If you have a specific type of formatting that you'd like to apply but can't, I'd be happy to add a new bbcode tag to pull that off.
Hi Adam,
thanks for this hint. Helps to understand why things that I'm used to do don't work in this place.
I use the app iA Writer on iPhone, iPad and Mac. It's a little easy to use powerful editor - very convenient, love it.
This app uses a markdown language similar to BBCode. You can mark your text and then copy it as html to include the html-code wherever you like.
Today I generated a document with a table in iA Writer that shows infos like the different angles of view of a potential FL15mm lens on the different devices for different Pentax Cameras (1/1.7, APSC, FF, MF). Thought it could be interesting for the forum members.
So I wanted to copy it as html out of my personal iA Writer document and show it in a thread without writing it down once more in BBCode. So I'd need the opportunity to include the copied HTML-code into the PF editor so that it is shown correctly.
In this case the usual table-HTML-Tags would be nice as add-ons in the PF editor (html-tags: table, colgroup, col, thead, tbody, tr, th, td). CSS should be possible too. It would be nice, if there's a way to get there. Thanks for asking!
best regards, acoufap
