01-28-2017, 01:12 PM   #1
Forum not working on Tapatalk
As the title says the forum seems to have stopped working properly on Tapatalk. No new posts are showing. I logged out and now get a network error when trying to log in.
01-28-2017, 04:28 PM   #2
clackers's Avatar
Same here!
01-28-2017, 05:39 PM   #3
This should now be fixed. Thanks for bringing it to my attention!
01-29-2017, 02:53 AM   #4
Class A's Avatar
Tapatalk is still not working for me.
I get a "Failed to connect to forum..." message and the "Loading..." message keeps spinning indefinitely.
Other forums work fine, so it's not my Tapatalk app or network playing up.
01-29-2017, 03:20 AM   #5
You may need to clear the app's cache, in case it's trying to connect to the non-secure version of the site.
01-29-2017, 06:44 AM   #6
Class A's Avatar
I have tried that but it did not help.
I then removed the forum from the list of forums within Tapatalk and added it again. I still get the same error.
What else can I try?
Is there a chance to get a non-secure connection via Tapatalk again?
Not sure why a secure connection is required in the first place.
I really, really depend on Tapatalk to follow what is going on on forums. I can't see myself migrating to using a web browser, independently of whether or not I'd be using the mobile or the full version.
01-29-2017, 12:28 PM   #7
I can confirm that tapatalk is working on my end, so don't worry- you should be able to get it to work as well.
If you're andriod using go to system settings -> apps -> tapatalk. There may be a "clear cache" button there. If not, look for "storage" on that page and it might be under there.
If this still doesn't help, look for "clear data" on that same page. This will force you to log in to your tapatalk account again and should definitely do the trick.
iOS has a similar page in the system settings.
01-30-2017, 02:23 AM   #8
Class A's Avatar
Thanks, Adam.
Unfortunately, the answer is "yes" and "no".
The reason why neither a cache clearance nor clearing the user data helped was that my tapatalk app version apparently is too old to work with the new system you put in place. The problem is, I have been using this older tapatalk version on purpose. It is still working fine with all the other forums I'm using, but stopped working with pentaxforums.com.
For testing purposes, I upgraded the tapatalk app to the latest version on a different phone I'm no longer using. Once I do that, I can connect to pentaxforums.com via tapatalk again. However, I won't upgrade my tapatalk app on my real phone because later tapatalk app versions became just terrible in the amount of adverts they constantly display. I think the UI got worse as well (less clean) but the adverts are just unacceptable for me.
I have little hope you'll be able to get a compatibility mode going for older versions of tapatalk, so I guess I'll become a less frequent forum reader from now on. There is no way I'll ever "upgrade" my current tapatalk app to one of the newer ones that have an overladen UI and spam one with adverts. I'll continue to use my old version with the other forums as long as they will work.
01-30-2017, 02:33 AM   #9
I actually updated the tapatalk plugin earlier today thinking that might solve your issue...how ironic! But it wasn't a major upgrade, so it's more likely that the old app simply doesn't support SSL.
I have just disabled ads on my end; I'm not sure if Tapatalk forces more ads upon users or not, but please do check if that improves the display at all.
If not, then as a last resort I would post about your issue on the tapatalk forums. They will probably just tell you to upgrade the app, but it's worth a shot I guess.
Remember we also have a mobile site, and it works pretty well. That would be another alternative.
01-30-2017, 02:34 AM   #10
How do you disable ads?
01-30-2017, 02:41 AM   #11
QuoteOriginally posted by slartibartfast01 Quote
Ads are currently disabled for all premium user groups (Pentaxians, site supporters, marketplace sellers, loyal site supporters) and active for other usergroups.
01-30-2017, 02:56 AM   #12
Class A's Avatar
Yes, unfortunately that seems to be the case. I wish it weren't necessary to use SSL via tapatalk.
Thanks for removing the ads from your end, but indeed tapatalk adds ("suggested") ads of its own. You can opt out of the ads by paying money (subscription or one time payment). I won't pay tapatalk as I don't want to support an approach in which people are sucked into an an approach (using a well-suited forum browser) only to be milked once they got used to the comfort.
Yes, thanks but I mentioned earlier that neither the mobile nor the full site work work nearly as well for me as tapatalk had been working. Too bad that my days of tapatalk browsing pentaxforums seem to be over.
01-30-2017, 03:50 AM   #13
Looking at the code it's actually scary if you're not running SSL...I feel bad for not making the move earlier.
I'd still ask their support team just in case, though in the long run I'd expect more and more sites to start breaking as the industry puts pressure on site owners to switch to SSL.
01-30-2017, 07:41 AM   #14
Rupert's Avatar
I use Avast Safe Zone Browser...wonderful!I had to log in today for the first time in ages, which was sort of a small hassle but not a big pain. It seems a little overkill but not prohibitive. If it will keep out all the renegade squirrels that run amok here, I'm all for it! I bet others see the value in that too!
Regards!
01-30-2017, 10:55 AM   #15
I was having problems with Tapatalk over the weekend, but it is working for me now.
forum, issues, log, message, tapatalk
FluCard not working on Windows 10 tablet marabella Pentax Camera and Field Accessories 15 09-16-2016 04:55 PM
Battery grip not working on K5IIs Gampa Troubleshooting and Beginner Help 7 05-18-2016 03:23 PM
Sigma 18-250 not working on KS2 Glen_S Pentax K-S1 & K-S2 5 12-27-2015 05:12 PM
Aperture is not working on k-50 getting back into it Troubleshooting and Beginner Help 4 07-23-2015 06:33 PM
Error NSFW does not appear in Tapatalk selar Site Suggestions and Help 3 04-14-2011 01:34 PM
All times are GMT -7. The time now is 09:01 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
