Background info: there are essentially two ways to rotate a JPG image. One is to rearrange the data in the file so the pixels are actually in the other orientation, as an image editor would do it. The other is to just make a note in the file header directing the viewing software how to orient it.
On the trash can picture from the
earlier thread, I'd expect to see an EXIF tag declaring orientation of either 90 or -90 (since I can't remember offhand whether the convention means "it is rotated this way" or "please rotate it this way"). But instead it has this:
Orientation : Rotate 180
To settle the question, view the EXIF on your own copy of the image file. If it says 180, the problem is somewhere on your end. If it says 90 or -90 then PF screwed up when processing the file.
Either way, a certain cure is to turn off auto-orientation on the camera, and use an image editor to do the rotations before uploading to PF. You shouldn't have to do that, but you can expect it to always work.
