not a bad start.
I notice a couple of areas where the information could be improved however,
For example, on the K10D line you should have a "note" beside M for manual mode, as the metering is innacurate,
Additionally for all DSLRs you should note the AV mode is only available at maximum apature, not really a full AV mode,
It would be useful to have M42 lenses also, abd M42 bodies, because as I understand it, there are at least 3 fundamental differences in M423 bodies.
Ones that only meter stopped down, ones that meter wide open, and stop the lens down to shoot, and then there are a few rare examples of M42 bodies with full auto exposure (AV mode)
I can see flash, and metering being added as either different columns under each lens, or perhaps a different color circle with a code inside it.
