01-03-2023, 12:09 PM   #1
January Contest
I couldn't download the photo I'd like to submit for the January contest. I had already used the photo in a previous contest last year, but I'd like to use the same photo. Photo: Boat meets Water
01-03-2023, 12:13 PM   #2
pschlute's Avatar
RE: January Contest
PM Sent to user:
RE: January Contest
If you want to submit a previously entered photo, the best thing to do is rename it and then it should work.
Sent as Moderator
01-03-2023, 01:10 PM   #3
RE: January Contest
Yes,
I did try to re-name it before I downloaded it. It still came up with a message with the previous name.
---------- Post added 01-03-23 at 01:12 PM ----------
you might have to just re-set my submittal page. Maybe delete it? So I can go back and re-name the photo and start over.
01-03-2023, 01:19 PM   #4
pschlute's Avatar
RE: RE: January Contest
PM Sent to user:
I have not re-set anything.
Can you link to the picture concerned?
You should be able to simply download it and rename it.
Sent as Moderator
01-03-2023, 04:36 PM   #5
If the photo is already uploaded, there's no need to re upload it- you can just embed the existing one directly.
01-03-2023, 04:59 PM   #6
OrchidJulie's Avatar
Done.
01-03-2023, 05:07 PM   #7
QuoteOriginally posted by Markpszk Quote
Yes,
Mark, no need. If you uploaded it once, it's in the system. Here's how to get it in a new post:
Write your new post, press enter and move the cursor down a line or two, and select "go advanced" from the options at the bottom.
Look on the right side of the screen, you'll see the "smilies" available, and below that, "insert album photos"
Select "insert album photos" and on the next screen, you have options to select an image from several sources, select "attachments" and your previous upload should appear there (if you've posted a lot of images, you'll have to scroll the entries to find the one you want)
Click on the image you want and it will be embedded in the new post.
Hope that helps!
01-03-2023, 06:49 PM   #8
Thank you!
I think it worked
01-04-2023, 09:47 AM   #9
You're welcome, Mark. Glad to help.
And yes, it worked, the image is there in the contest entries. Good luck!
01-05-2023, 01:40 PM   #10
pschlute's Avatar
QuoteOriginally posted by OrchidJulie Quote
Hope that helps!
It certainly helped me
I had no idea that functionality existed.
Thanks Julie.
01-05-2023, 02:21 PM - 1 Like   #11
Thanks Julie.
You're welcome, Peter, glad to help!
It is indeed a useful function, especially if you've run into that "you've already uploaded this file" wall and yet you see other members posting the same image in multiple places.
That's how they do it!
contact, contest, form, january, message, moderator, photo
Caption Contest January 1st to January 7th bertwert Weekly Photo Challenges 14 01-08-2019 07:59 AM
Caption Contest Photo Caption Contest -- January 23 - January 29, 2018 noelcmn Weekly Photo Challenges 13 02-01-2018 09:33 AM
Weekly Challenge Photo Caption Contest -- January 15 - January 22, 2018 aslyfox Weekly Photo Challenges 12 01-23-2018 12:38 AM
Weekly Challenge Weekly Caption Contest January 20 to January 27, 2014 Steve.Ledger Weekly Photo Challenges 64 01-29-2014 11:57 AM
Weekly Challenge Weekly Caption Contest January 12 to January 19, 2014 Bill2849 Weekly Photo Challenges 21 01-19-2014 06:34 PM
All times are GMT -7. The time now is 06:19 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
