Originally posted by ftpaddict Yep, that's the only way you can do it, as far as I can tell.
If HTML had been enabled, you could have done it like this:
Code:
<a href="http://www.pentaxphotogallery.com/heinrichlohmann">PPG</a>
In the upper right corner is the box to alternate enable/disable
HTML Code display. With CODE enabled, insert the full URL using the insertion dialog as usual
PPG
A second instance of your URL will be highlighted before the Close URL box. Replace the second instance of the URL with your shortcut.
To check the entry, hover your mouse over the shortcut. The URL should display in the lower left linkbar of your browser (at least it does in Firefox).
