Georgis, not long ago I was in the same boat as you. I was shooting jpg because most of the time I was satisfied with it and I had the same frustration with raw as you seem to have now. I also don't have much free time and don't want to waste that little time in front of my pc (working 9-10 hours with it is enough), I want and try to have everything (exposure, wb, framing, etc) right before pressing the shutter release button.
What's changed that now I shoot raw? I found a good app that has the features and works in way that I like, and I could create a nice preset which gives similar tones and colors as the camera/DCU jpg. So now I don't really spend more time in front of the pc than before, the only difference in time is a few seconds to (automatically) import the raw files to my catalog and a few minutes to generate resized jpgs for web & email use. So after auto import I quickly review the images one by one (the same way as I did with jpgs before), if one needs adjustments then I either quickly make those (like enabling noise reduction, correcting wb, etc) or mark the image for later processing (if I don't have the time or mood to PP it), after reviewing I select all and generate low resolution (1200 pixels on longer side) jpgs with one keypress.
For most of my photos my default preset gives good result and I don't need to change anything. Why using raw is good for me: on high ISO photos I can apply noise reduction as needed and only on selected areas, I can correct some mistakes (no matter how I want and try to get it right in the camera, sometimes mistakes like accidentally dialing in exposure compensation can happen), with output batches it's just a keypress to generate different type of output images (low res jpg for web, full res jpg, full res tiff for printing, etc), I can have many versions of the same photo and apply different non-destructive image editing to each without manually creating copies of the master file, and many other small things.
I think if you could find an application that suits your needs and working style, and could create a preset that gives you good result then your opinion and experience would change and you'd probably never look back
If not then that's ok too, raw is just an option that we either use or not use.
