If you check mark some files and then close Pentax DCU4 without unchecking them you will get this error. A reinstall does not clear the contents of the Pentax Application Data directory. I don't use DCU4 (I'm a SilkyPix Pro user), but I just confirmed this by getting DCU4 to crash for me.
The file you need to delete is CheckInfo.ini. In my case it's in the C:\Documents and Settings\Dan\Local Settings\Application Data\Pentax\Digital Camera Utility 4 directory. Application Data is a hidden directory.
You can locate it by doing a search for checkinfo.ini, including hidden files & directories in the search options. Then delete this file. Just worked for me!
If you want, put a shortcut to this directory on your Desktop or in your Photo Programs folder so you can easily get there if it happens again. You could name the shortcut "Delete CheckInfo.ini in here".
You could also create a batch file in Notepad and run it.
Name the text file Fix_DCU.bat
The text file contains 1 command line. Use the right full pathname for you. del "C:\Documents and Settings\Dan\Local Settings\Application Data\Pentax\Digital Camera Utility 4\checkinfo.ini"
There were some stability fixes also in v4.21 so make sure you're running at least that version.
Dan
